New Holland t5000 idle issue
/ New Holland t5000 idle issue #1
futbalistos123
New Holland
Hello, I bumped into a problem lately. I started having issue with t5050. My problem is that when I increase rpm and let of the gas immediately, idle rpm fluctuate for about 3 seconds and then settle or when there is a change in load. When I slowly decrease rpm, it doesn't do that. Could it be a problem with injection pump, overflow valve or an air leak at return line? Or maybe is it just some junk stuck in the fuel lines or at the bottom of the tank? I changed the fuel filter, but with no improvement, although I think it improved performance. Please, do you have any idea what it could be? Maybe fuel pump needs adjusting?? Thanks for reply
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Bomag Roller (A63118)
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
John Deere Z997R (A60462)
John Deere Z997R...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
