Loader New Holland T 4.75 Is there a separate fluid reservoir for the 655TL loader?
   / New Holland T 4.75 Is there a separate fluid reservoir for the 655TL loader? #1
seankerns
Morrow
New Holland T4.75 Tier 4A
Hi,
Owned this tractor a little less than a year. It came with a 655TL front end loader. I have been through the manual front to back, but can't find in the manual whether the FEL uses the same reservoir/fluid as the transmission, which has a dipstick and filler cap in back near the top link for the hydraulic lift.
Is it just the one fluid, same reservoir, or is there somewhere else I should be checking the fluid?
There is a small plastic reservoir up on the passenger side firewall which has a "Use Mineral Oil Only", and I can't find in the manual what that is for. Looks kind of like a brake or clutch fluid reservoir, but not sure. I have the hydraulic forward/reverse shuttle on this tractor, if that makes a difference.
Anybody?
If all else fails, I can call the dealer I bought it from, but I hate looking like a doofus if I don't have to.
Thanks,
Sean
   / New Holland T 4.75 Is there a separate fluid reservoir for the 655TL loader? #2
Same fluid, same reservoir.
   / New Holland T 4.75 Is there a separate fluid reservoir for the 655TL loader? #3
The "Use Mineral Oil Only" reservoir should be your brake fluid. Do NOT put automotive type brake fluid in it.
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Informational Lot - Financing (A56436)
Informational Lot...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
