New Holland Subcompacts?
   / New Holland Subcompacts? #1
eagle107
NY
Kubota and John Deere Tractors
Guys,
I am in the market for a subcompact tractor now. I am currently looking at the John Deer 1023e or 1026r, Kubota BX series or Mahindra Max series. Has New Holland announced any plans to unveil a new subcompact line soon?
   / New Holland Subcompacts? #2
The Boomer 20 and 25 will be arriving at dealers starting in about April. We have 5 on order and they have since been shipped. They will be 20 and 25 hp respectively.
Are they LS or Mitsubishi type subcompact tractors?
   / New Holland Subcompacts? #4
Yes. They are Mitsubishi powered subcompacts manufactured by LS. There were some emmissions issues with them, that is why there was a gap in the NH lineup for almost a year.
Thank congress and the EPA, but NH now has a full line up.
   / New Holland Subcompacts? #5
The boomer 20 and 25 are not subcompacts.
New Holland still does not have a full line up. no sub compacts, no cab tractors, etc. CNH needs to either make a commitment to the compact tractor business and get the product right, or cut their losses and concentrate on farm equipment.
   / New Holland Subcompacts? #6
I agree that there are still gaps, I guess I didn't think we were talking about the entire NH lineup here. I also agree with a little more reading that the Boomer 20 and 25 are Class I tractors not subcompacts. At the same time, they may fit the bill for the OP.
   / New Holland Subcompacts? #7
Frame size on the NH Boomer 20 and 25 will be larger than the Deere models you stated above, otherwise the hp and other specs are comparable.
NH
Mitsubishi S3L2 3 Cyl. Diesel Engine
27.0 Gross Engine hp @ 2700 rpm
19.9 PTO hp @ 2700 rpm (HST)
80.4 cu. in. (1.3L) Displacement
1433 lb. (650 kg)
Tier 4a compliant
Turn-Buckle Type Leveling Mechanism
Naturally Aspirated
Chain Stabilizers
Under Hood Muffler / Exhaust
Fixed Link Ends
Single Element Air Cleaner
Full-flow, Spin-on Oil Filter
ROPS
6.6 gallon (25L) Fuel Tank
2-Post, Foldable Roll Bar
JD
MODEL 1026R
Engine
Manufacturer Yanmar 3TNV76
Engine HP (kW) - gross 25.2 (18.5) per ISO 97/68/EC
PTO HP (kW) - Gear transmission ---
PTO HP (kW) - Hydrostatic transmission 18 (13.4) per SAE
Rated engine speed, rpm 3200
Type Diesel
Operating range 1360-3370
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 68 (1.115)
Bore and Stroke, mm (in.) 76x82 (2.99x3.23)
Air Cleaner Dry type with safety element
Fuel Tank Cap., US Gal. (L) (Open; Cab) 5.6 (21.2)
Hydraulics Type Open Center
Pump Rated Output, gpm (L/min.) 6.3 (24)
Steering 2.8 (10.8)
Implement 3.5 (13.2)
Pump Type Gear
Maximum Operating Pressure (PSI) 2000
Thanks! To be honest, the Boomer 20 & 25 seems to be the same tractors as the LS J23HST and J27HST. I would probably go to the LS dealer to look at them seeing he already has them on his lot.
Neil,
Any news if Kubota has an update coming/redesign on the table for the BX models?
   / New Holland Subcompacts? #9
Neil,
Same as LS.
   / New Holland Subcompacts? #10
So, these sound like the comparable to a Kubota B2620 and B2320. So, the JD model would be the... 2320 and what? John Deere's line has a couple of holes in it too. The Boomer 30 would be like the B2920, B2630, or the JD 2520 or 2720? It really gets strange trying to figure out what apples to apples is when doing comparisons. I guess it all runs down to where their big markets are. I ran into a dealer that wouldn't mess with a Kubota B series any smaller than a B2920. It was where he was located, and what his local customers wanted.
I wouldn't say NH needs to cut out of the market because they don't have an apples to apples direct competitor. That's silly. What I do find irritating is that every one is selling re-branded tractors with slightly different sheet metal and different paint. JD, at least, makes an effort to engineer some differences into their tractors.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
