New Holland Subcompacts?
/ New Holland Subcompacts? #1
eagle107
Gold Member
NY
Kubota and John Deere Tractors
Guys,
I am in the market for a subcompact tractor now. I am currently looking at the John Deer 1023e or 1026r, Kubota BX series or Mahindra Max series. Has New Holland announced any plans to unveil a new subcompact line soon?
/ New Holland Subcompacts? #2
The Boomer 20 and 25 will be arriving at dealers starting in about April. We have 5 on order and they have since been shipped. They will be 20 and 25 hp respectively.
Are they LS or Mitsubishi type subcompact tractors?
/ New Holland Subcompacts? #4
Yes. They are Mitsubishi powered subcompacts manufactured by LS. There were some emmissions issues with them, that is why there was a gap in the NH lineup for almost a year.
Thank congress and the EPA, but NH now has a full line up.
/ New Holland Subcompacts? #5
The boomer 20 and 25 are not subcompacts.
New Holland still does not have a full line up. no sub compacts, no cab tractors, etc. CNH needs to either make a commitment to the compact tractor business and get the product right, or cut their losses and concentrate on farm equipment.
/ New Holland Subcompacts? #6
I agree that there are still gaps, I guess I didn't think we were talking about the entire NH lineup here. I also agree with a little more reading that the Boomer 20 and 25 are Class I tractors not subcompacts. At the same time, they may fit the bill for the OP.
/ New Holland Subcompacts? #7
Frame size on the NH Boomer 20 and 25 will be larger than the Deere models you stated above, otherwise the hp and other specs are comparable.
NH
Mitsubishi S3L2 3 Cyl. Diesel Engine
27.0 Gross Engine hp @ 2700 rpm
19.9 PTO hp @ 2700 rpm (HST)
80.4 cu. in. (1.3L) Displacement
1433 lb. (650 kg)
Tier 4a compliant
Turn-Buckle Type Leveling Mechanism
Naturally Aspirated
Chain Stabilizers
Under Hood Muffler / Exhaust
Fixed Link Ends
Single Element Air Cleaner
Full-flow, Spin-on Oil Filter
ROPS
6.6 gallon (25L) Fuel Tank
2-Post, Foldable Roll Bar
JD
MODEL 1026R
Engine
Manufacturer Yanmar 3TNV76
Engine HP (kW) - gross 25.2 (18.5) per ISO 97/68/EC
PTO HP (kW) - Gear transmission ---
PTO HP (kW) - Hydrostatic transmission 18 (13.4) per SAE
Rated engine speed, rpm 3200
Type Diesel
Operating range 1360-3370
Aspiration Natural
Cylinders/Displacement, cu. in. (liters) 3 / 68 (1.115)
Bore and Stroke, mm (in.) 76x82 (2.99x3.23)
Air Cleaner Dry type with safety element
Fuel Tank Cap., US Gal. (L) (Open; Cab) 5.6 (21.2)
Hydraulics Type Open Center
Pump Rated Output, gpm (L/min.) 6.3 (24)
Steering 2.8 (10.8)
Implement 3.5 (13.2)
Pump Type Gear
Maximum Operating Pressure (PSI) 2000
Thanks! To be honest, the Boomer 20 & 25 seems to be the same tractors as the LS J23HST and J27HST. I would probably go to the LS dealer to look at them seeing he already has them on his lot.
Neil,
Any news if Kubota has an update coming/redesign on the table for the BX models?
/ New Holland Subcompacts? #9
Neil,
Same as LS.
/ New Holland Subcompacts? #10
So, these sound like the comparable to a Kubota B2620 and B2320. So, the JD model would be the... 2320 and what? John Deere's line has a couple of holes in it too. The Boomer 30 would be like the B2920, B2630, or the JD 2520 or 2720? It really gets strange trying to figure out what apples to apples is when doing comparisons. I guess it all runs down to where their big markets are. I ran into a dealer that wouldn't mess with a Kubota B series any smaller than a B2920. It was where he was located, and what his local customers wanted.
I wouldn't say NH needs to cut out of the market because they don't have an apples to apples direct competitor. That's silly. What I do find irritating is that every one is selling re-branded tractors with slightly different sheet metal and different paint. JD, at least, makes an effort to engineer some differences into their tractors.
/ New Holland Subcompacts? #13
Neil,
I've not seen or heard anything, but as the normal refresh cycle of models go they should be comming about shortly. That said, Kubota seems to be going about 10 different ways right now and its possible they are putting engineering resources elsewhere.
/ New Holland Subcompacts? #14
Gaps? You must work in Sales and have a small part of your gross come from CUT's.
With the end of the Shibaura contract and the execution of CNH's deal with LS, CNH has all but abdicated its position in the CUT marketplace. I don't know about your end of PA, but here it is nearly impossible to get anyone to sit on a Boomer let alone buy one. I'm all but certain we sold more Kiotis in the first three months we had that contract (first quarter 2011) than we did Boomers and Workmasters in all of 2011.
Shibaura subcompacts are coming to your local Kioti dealer soon, by the way.
/ New Holland Subcompacts? #15
Oh I feel the sting of no more ISM tractors, there is no question. Taking a customer that has a TC or the like and showing them a new Boomer is tough. Staying positive is the key, as the decisions that are made by the higher ups are often not the best moves in the eyes of everyone. It was not that long ago that the dealer body was crying about "an over speced and over priced ISM" lets keep in mind. As you probably know better than I, this stuff is cyclical and maybe some one will eventually wake up and make a reasonable OEM agreement. As for Shibura and Kioti, it is disappointing for the NH guys and some accountability needs to surface for the break down in CNH's relationship. However, kudos to Kioti. Do you find the Kioti to be superior to the other CUT's on the market?
/ New Holland Subcompacts? #16
There are often questions here about the 'best' this or that available, in other words, an offering that is universally judged to be superior. If there were any one 'best' version of a particular product, other brands would disappear over time. We needed to replace a popular and successful product that was no longer available; thinking (perhaps correctly) that CNH had failed in that regard. There is little doubt that Kioti tractors offer features and value not available to us or our customers from CNH. We inherited a substantial local Kioti customer base that exhibits a high level of product satisfaction, and we are building on that group's level of dealer satisfaction. There is a distinction to be made between remaining positive about a product line and blindly following along. The success of the CNH marketing strategy falls a distant third goal for us below the happiness and success of our customers and that of our own dealership.
/ New Holland Subcompacts? #17
There is no question that the priority of a business must be the satisfaction of its customers, no one is saying let the blind lead the blind. If NH, Kioti, or any other company does not offer what a customer wants and needs, it (in my opinion) is the responsibility of the customer AND dealer (to the best possible extent) to find them the best suitable machine for their needs and budget regardless of color. That's exactly why there are forums like this. I would not be honest if I said that I wasn't partial to blue, but I am not oblivious to the rest of what is out there.
The initial question here was if NH was going to offer a subcompact. The answer is they are introducing a 20 and 25 hp class I frame sized tractor that has similar specs to the JD the OP was also looking at. I did not state that "the new Boomer 20 and 25 is the greatest thing on earth simply because NH made it" from the top pf the message board, I simply stated what is coming.
I will admit that I was a little over the top saying "NH now has a full lineup", and for that I realize a little chastisement is deservedly coming my way.:laughing:
/ New Holland Subcompacts? #20
I'm surprised you're not selling more Workmasters. Our WM55 is fantastic. We bought ours in October and have about 90 hours on it now. It's a solid classic 4wd tractor. The plate steel is much thicker than other tractors in the same hp range. Minimal plastic to get brittle and crack. Everything is easy on/off connectors.
The only negative is the size of the fill hole in the transmission. It could use a bigger fill hole.
I have to say, I'm surprised that more people aren't snapping these up for small acreage farms.
2006 FREIGHTLINER COLUMBIA (INOPERABLE) (A65643)
2006 FREIGHTLINER...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
New 4-Wheeler Tires (A65640)
New 4-Wheeler...
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
Ford Golden Jubilee (Model NAA) Tractor (A66285)
Ford Golden...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
