New Holland/Ford 1530 - new to tractors
   / New Holland/Ford 1530 - new to tractors #1
oddodaoddo
Virginia
None
Hello,
I am totally new to tractors. There is a NH/Ford 1530 for sale locally that only has 250 hours and looks pretty well kept. I am very "green" when it comes to tractors but I have been looking for a while to get one. I qualify to get a loan and buy a new 40HP tractor (any of the big names or koreans) but I really cannot justify the expense and want to start small. Hence, I am looking at the 1530. Can someone explain briefly what it takes to put a FEL on these tractors? Where would I even go to get one installed? Is this something done by a local NH dealer or would this be a job for an independent tractor shop? I am in SW Virginia near Roanoke...
Thank you all!
   / New Holland/Ford 1530 - new to tractors #2
Hello,
Thank you all!
I can tell you your better off if buying a used tractor to get one with a loader already on it. They are not cheap and getting it to work on your tractor will cost also. Others may have other opinions but I personally think you will be money ahead.
   / New Holland/Ford 1530 - new to tractors #3
I agree - find a tractor that already has a loader.
Guy.
   / New Holland/Ford 1530 - new to tractors #4
Guy.
x3 ...If the OP wants a loader (and who doesn't?), then he needs to buy a tractor with a loader.
It is will be nearly impossible, to find an OEM used loader to fit a specific tractor.
The cost of buying/mounting/adapting a new aftermarket loader will be high.
IT IS NOT COST EFFECTIVE TO BUY A TRACTOR WITHOUT A LOADER.
If the OP wants a tractor with a loader .... he should, BUY a tractor with a loader !
Thank you all for your replies, I will skip this tractor then.
   / New Holland/Ford 1530 - new to tractors #6
I may be in the minority, but I disagree. That tractor may be a great deal. Loaders can be found, but expect to do some research and looking to find one. They aren't hard to install, provided you can find the mounting frames. Find a loader manufacturer, call them and ask if they can help. Then use that information to decide if you want to add a loader to the 1530. You may be pleasantly surprised, and end up with a great setup.
Would it be easier to buy one with a loader? Yes. But there isn't a single tractor out there that is built with a loader at the factory (farm tractor that is). The dealerships install them, and it's not a huge deal. I've installed many of them on green and blue tractors, usually take about 4 hrs.
   / New Holland/Ford 1530 - new to tractors #8
If you want to buy a tractor without a loader I would highly recommend locating a loader for it before you buy the tractor. They are a few places in PA that sell used equipment for Ford/New Holland tractors, try calling Long Lane Tractor or Weavers Compact Tractors.
2008 Hooper 20ft Gooseneck Flatbed Trailer (A51572)
2008 Hooper 20ft...
Woods 9204RD-2 Flexwing Finish Mower (A51573)
Woods 9204RD-2...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
UNUSED CFG MX12RX EXCAVATOR (A51247)
UNUSED CFG MX12RX...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
