New Holland Boomer problems
   / New Holland Boomer problems #11
I put Howe's Lubricator Diesel Treat in after I drained the tank and changed the filter. I put in less than an ounce because it said 32 oz treats 160 gallons. Should I use more?
That would be 1 ounce for each 5 gallons. A little more would not hurt.
Thanks for all the suggestions. I added the diesel treat to the fuel, filled up my tank and started using the tractor. After about 15 minutes it started to miss again. I babied it as before until it started running properly. I mowed up my pond dam and it started missing again. Same as before. I kept working with it and after a while it started to run fine. I ran it for another 15-20 minutes and it ran great. Maybe this worked all the moisture out of the system for now. I'll use it again in a couple of days and see if it still runs well. I really appreciate all the help I have received here.
   / New Holland Boomer problems #13
I have a New Holland Boomer24 with only 115 hours on it. It is a 2014 model which I purchased new in late 2015. Last year it started missing and pulling down when I was mowing. I seemed to be able to mow for 45 minutes before this started. It pulls down, I turn off the PTO and in a bit it ramps back up. It may mow a couple of minutes before it happens again. The dealer said I needed a fuel filter. I purchased one, put it in and it ran great for about an hour. The next time I used it, the missing started after 30 minutes. It was at the end of the summer, so I didn't pursue the matter. I had to use it in the winter to move snow in my driveway. It ran fine. This summer I started out mowing and it ran fine. I was able to mow about 3 times when it started the missing again. It takes me about an hour to mow. I called the dealer and again they said fuel filter. The one I put in before didn't have 20 hours on it but I said ok. I purchased another filter and this time I drained what little fuel that was left in the tank and installed the new fuel filter. I put a couple gallons of diesel in and it ran perfect. I mowed for an hour and a half without issue. The next time I started it it was back to the same issue. Started missing and losing power after 45-60 minutes. The dealer has no clue as to what may be causing it. He will come get and return it for $150 plus whatever other charges there will be.
Has anyone experienced an issue like this or have any ideas as to what may be wrong?
I'm experiencing the identical problem and have been for about two-three years. I'm on a '15 Boomer 24 with 200 hrs on it, whenever it gets below half a tank of fuel it does the same thing. If I keep it topped off, there is no problem whatsoever. I can create this same issue if I pick the front end of the tractor up with the bucket with about 2 gallons of fuel in the tank. To date I've tried the following:
1. opened gas tank cover when it starts acting up - no dice
2. bought a new gas tank cover thinking the vent was plugged with dirt - no dice
3. changed out fuel filter - no dice
4. blew out line back to tank when I changed the fuel filter - no dice
5. checked all hoses to/from the tank , no holes or kinks etc - no dice
I noticed the fuel bowl is not emptying with fuel when this acts up (indicating there is no problem with an obstruction back to the fuek tank), I'm wondering it it is a fuel injector pump issue. I took it to my dealer this past Monday and he can't find any immediate issue. I looked up the fuel pump and the damned thing costs in excess of $2k. Given my luck that's probably the issue and man am I kicking myself in the ass for not dragging it back to the dealer while it was still under warranty. I have had no other issue whatsoever with this little tractor and basically love how well it performs for light house work, snow removal etc.
Anyone else experience the same issue and what was the fix? Thanks!
   / New Holland Boomer problems #14
Most of our tractors regardless of how stored, are not stored in climate controlled locations (heated and cooled). This as temps rise and lower with day highs to overnight lows, the mostly closed environment of our fuel tanks (vent does make a difference for variety of reasons I will not address here), condensation inside the tank is an issue in most parts of the country. The result is that regardless of the season you have a possibility of moisture in your fuel.
READ UP ON ALGAE IN DIESEL!
There are really only a couple of options to deal with this issue, fuel additives and a full tank of fuel when finished using tractor.
I suggest using both approaches. Full tanks reduces air space in the tank so less chance for condensation. Additives—you may want to periodically include an anti algae. Again read up on the topic!
I am deliberately not mentioning a fuel additive, but there are many quality brands available. One caution, read the labels for what you wish to treat (gelling, water in fuel, algae, injector cleaning) just to name a few issues.
This should not need to be said, but…be sure it is safe for diesel!
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2011 Western Star Trucks 4900 Tri Axle Truck, VIN # 5KJNALDR4BPBA7822 (A54865)
2011 Western Star...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
