Backhoe New holland Backhoe attachment on a john deere
   / New holland Backhoe attachment on a john deere #1
dartdale
Pocahontas,Ar.
4400 john deere
Looking to buy a used newholland backhoe attachment and install it on my 4400 john deere. Will the hydralic connections be the same?
   / New holland Backhoe attachment on a john deere #2
you can always swap the ends of the hoses to match your fittings. In general id say yes.
welcome to the boards!
and most people dont recommend running a backhoe off a 3pt off a CUT, most highly recommend a subframe. you'll likely need a custom one to match the NH hoe to the JD tractor
   / New holland Backhoe attachment on a john deere #3
If you have welding capabilities you can build a custom subframe. There are several threads about building them on here.
   / New holland Backhoe attachment on a john deere #4
You may run into a closed center vs. open center situation. As I understand it most John Deere tractors are closed center. Don't know about New Holland, just a matter of changed some internal plugs and possibly a relief valve. Found this on another website:
Q: What is the difference between an open and closed system?
A: The terms Open system and Closed system refer to two methods of reducing the pressure on the pump, which minimizes wear and tear.
Open systems are common on logsplitters and most tractors prior to 1960. When an open system is in neutral, an open center valve connects all lines directly back to the reservoir, bypassing the pump. The pump is always pumping, allowing a constant flow of oil without building pressure.
Closed systems are common on construction machinery and modern farm equipment, including most John Deere models. When a closed system is in neutral, the closed center valve blocks the flow of oil from the pump. The oil travels instead to an accumulator, which stores the oil under pressure.
   / New holland Backhoe attachment on a john deere #5
Since his tractor is a cut the 4400 is an open center design. Most john Deere utility tractors and below are open center for simplicity.
   / New holland Backhoe attachment on a john deere #6
Thanx! Nice to know that.
Thanks guys I appreciate the info. I am new to tractors and such so any and all help I can get is appreciated!
CFG Industrial MX12RX (A56469)
CFG Industrial...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft Insulated Bucket Truck (A55852)
2012 Freightliner...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2015 Toro Reelmaster Gang Mower Attachment (A55851)
2015 Toro...
