New Holland 68 square baler
   / New Holland 68 square baler #11
Farmerofva
Welcome to TBN
Before operating baler/cycling needles one needs to be sure plunger head stop is functioning properly!!!!!!!!!!!!
Thanks for the welcome .. I thought I did time everything according to the manual I will try it again soon I need to retime I guess the rake and the plunger. I also wondered if I definitely have to use aisle or could plastic be used? My manual does tell me how to time everything.
   / New Holland 68 square baler #13
Glad it was not your gearbox.
In the last post, I'm assuming that you're asking about Sisal or plastic twine. I'll leave that to someone who has one of these, but I'm guessing Sisal. Every baler that I've ever been around works best on Sisal. Most people only use plastic twine because it's cheaper, not better.
   / New Holland 68 square baler #14
Plastic is better and cheaper. Plastic is more slippery, so the bale case and knotter friction clamps must be tightened to prevent it from bunching up during needle flyback. Might be time to sharpen or change-out the 60 year old cutoff knives, too. It's not rocket science, just attention to details. The downstream supply chain will appreciate tighter bales, easier to see the twine when unloading and stacking, easier to see the cut strings after feeding, denser bales, less barn space needed and the rot resistance of the packaged and delivered hay.
We don't yet get hay from China or Terra del Fuego, and it can't be 3D printed, so being able to produce your own this coming year is going to save a lot of animals from starvation or slaughter. Around here, even with good weather, cheap fuel, and sprawling subdivisions in former hay fields, horse hay was selling for $6 to $9 per bale, you pick up. Not much left either, only round bales, unless you want to drive 50 miles each way to pick it up in your Prius (put a few extra on the roof). [- Just a side note about my neighbor's predicament !]
I just was asking cause I bought a pallet of plastic and wondered no biggie I can use Sisal ... What you say makes sense thanks
Thanks for the input yea I had people offering 100.00 per 4x5 roll I had but I didn't sell it cause I needed it. I actually bought 2 square balers a NH 66 and of course the 68 cause I really hated seeing the waste from the goats/sheep on the round bales. I figure if I can get both running if something happens I can hook to the other and keep rolling and get it done. Here out the barn for horse quality hay as they call it is going for 15.00 a bale
   / New Holland 68 square baler #17
If you have the time and the knack, you can test your 'new' baler(s) by unrolling the round bales and feeding the good hay from them into your 65 and 68 to test the machinery, AND to give you a more manageable hay supply.
   / New Holland 68 square baler #18
I had a 66 ( next model down from the 68) and never had anything like this.---You do need to go over the whole thing and get the timing right or it will never work. ---Timing balers just right is way worse that any engine could ever be! ----- How many links are in your chain? is the chain worn out? ( sounds like this chain is the problem child here) Start right off with a new chain,--install it as per instructions in the book ( yes the book tells the procedure of how it's done) and it should work. We baled a LOT of bales every year with the old 66 and every 2 years we put a new timing chain on it because of the wear caused by the dirt that they run in.
Whatever you do DON'T try to use that plastic crap in a 66! ---I know for a fact it wont work!--nothing you try to set will make it work either. The knotters on these depend on the thickness of the regular twine to tie properly! ---I know guys use plastic in other balers, but not in a 66 ---not even sure bout a 68 --- nobody around here used the plastic crap.
That's what I planned to do to test them out and go from there.
The 66 seems to be in good to go shape I will test it first before I mess with the chains probably.
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2007 CHEVROLET Silverado (A56858)
2007 CHEVROLET...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
