New Holland 630 with 38 pto hp?
   / New Holland 630 with 38 pto hp? #11
Only raise the pickup for transport.
I'm baling in turns, pto has to stay running until you tie and drop the bale.
   / New Holland 630 with 38 pto hp? #12
Here is a picture off the net.
The chains on either side of mine are missing. I think they are just for transport anyway. I'll see if my tires wheel adjust down as they are all the way up on my baler.
That photo is correct. I leave mine set in the same place all the time, just so the pickup wheel barely touches the ground. If you run pickup too low, I find it plugs baler plus is harder on tines as the pickup slip clutch will kick out....then plug the baler....
   / New Holland 630 with 38 pto hp? #13
As long as the pulley is there you can make the chain and cable up with basic hardware store chain, cable and cable clamps. I've had to replace the cable on mine.
BUNDLE OF 60" X 23" EXPANDED METAL (A58375)
BUNDLE OF 60" X...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
Sedan (A59231)
Sedan (A59231)
Power Solutions International 6 Cylinder Power Unit (A57149)
Power Solutions...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
