New Holland 575 square baler
   / New Holland 575 square baler #1
dsumey
Albany OR
430 case
Hi all. I have a friend with a 575 baler. Baled hay and clover this year worked just fine. Started baling Ry grass straw and it is packing too tight, can hardly push out the bales. Backed off hydraulic cylinder and side plates, bales real tight and about 65lbs. Cleaned out chamber and can see no problem any suggestions welcome. By the way over ride clutch hot and braking shear bolts. thanks
   / New Holland 575 square baler #2
No buildup in the bottom corners of the chamber? How many pairs of wedges? Where is the hydroformatic gauge running? Side doors should be backed out flush with the chamber, NOT further which can cause hairpinning and more restrictions.
   / New Holland 575 square baler #3
Sounds to me that ryegrass is too high of moisture %. What is moisture % of ryegrass when baled? Can you get a small hand full(10-20 stems) & twist stems into in just a few revolutions?
It is was super dry, cut 3 weeks ago and raked about one week ago, it brakes when twisted. Had no problem last year same field. He removed wedges yesterday so will try tomorrow. We had light rain yesterday morning then sun.
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
2011 International DuraStar 4300 12ft Flatbed Truck (A55973)
2011 International...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
