New Holland 575 square baler
   / New Holland 575 square baler #1
dsumey
Albany OR
430 case
Hi all. I have a friend with a 575 baler. Baled hay and clover this year worked just fine. Started baling Ry grass straw and it is packing too tight, can hardly push out the bales. Backed off hydraulic cylinder and side plates, bales real tight and about 65lbs. Cleaned out chamber and can see no problem any suggestions welcome. By the way over ride clutch hot and braking shear bolts. thanks
   / New Holland 575 square baler #2
No buildup in the bottom corners of the chamber? How many pairs of wedges? Where is the hydroformatic gauge running? Side doors should be backed out flush with the chamber, NOT further which can cause hairpinning and more restrictions.
   / New Holland 575 square baler #3
Sounds to me that ryegrass is too high of moisture %. What is moisture % of ryegrass when baled? Can you get a small hand full(10-20 stems) & twist stems into in just a few revolutions?
It is was super dry, cut 3 weeks ago and raked about one week ago, it brakes when twisted. Had no problem last year same field. He removed wedges yesterday so will try tomorrow. We had light rain yesterday morning then sun.
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2025 CATERPILLAR 265 SKID STEER (A51242)
2025 CATERPILLAR...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
