Mowing new holland 477
   / new holland 477 #1
richardturner
keep breaking shear pin between wobble drive and knife am i going too fast or am i using wrong strengh of shear pin
   / new holland 477 #2
There are several possible reasons, does the cutter bar move easily and smoothly?
What grade bolt are you using?
Are the holes egg shaped?
   / new holland 477 #3
I ran a 477 for many years and only used NH shear bolts. The sickle blade should slide back and forth easily in the cutterbar, Ken Sweet
   / new holland 477
The cutter bar does not move freely is there something I should look for
   / new holland 477 #5
Yes, Look for the rock guards to all be in alignment and make sure the sections are all tight on the sickle. In addition, make sure the hold down clamps are all in the correct operating position. Ken Sweet
   / new holland 477 #6
It's NOT a shear pin. Its a drive bolt: especially hardened. Sounds like you have other problems. Remove the cutter bar if possible and align the rock guards and straighten the knife bar. If the bushing is shot, get a new one. There is no slack or play in the knife bushing.
   / new holland 477 #7
The bolt is a grade 8 and should be tighten as tight as you can get it and then go another round. All the mounting stud should be round and not oval. The sickle should slide in the guards freely without much resistance. Make sure the bushing is a OEM and that its adjusted properly
CFG Industrial MX15RX (A50121)
CFG Industrial...
2011 Dodge Ram 3500HD (A50120)
2011 Dodge Ram...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
