New Holland 4630 - Add hydraulics (because there aren't any)
   / New Holland 4630 - Add hydraulics (because there aren't any) #1
kheston
1996 New Holland 4630
My 1996 New Holland (Ford) 4630 didn't come with any hydraulic controls.
I purchased a hydraulic adapter plate with the hope of adding some, but have since learned this particular tractor requires closed center load sensing (CCLS) valves. The plate apparently won't help me. At a glance, CCLS system components appear to be a bit cost-prohibitive.
None of the attachments I plan to use with this tractor will require PTO and hydraulics in-tandem, so I'm considering using a PTO hydraulic pump instead of procuring/adding the required CCLS parts. Is this a good plan? Thoughts?
Here are some pics of where I believe hydraulics would be on my 4630 had the first owner added them:
This is what I thought I'd be able to do with the adapter plate (pic is not of my tractor):
   / New Holland 4630 - Add hydraulics (because there aren't any) #2
Your tractor appears to not have the engine mounted auxiliary hydraulic pump. In that case you can proceed and use an open center remote valve and/or the tapping manifold as pictured.
I didn't put together that the CCLS systems were only for tractors with the aux pump in my forum searches. Makes sense. Thanks for clarifying RickB!
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2013 RAM 4500 (A50323)
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
Harrell 3605 (A50123)
1969 Ford Continental (A51694)
1969 Ford...
