New Holland 461 haybine
   / New Holland 461 haybine #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I am looking at a new holland 461 haybine is their anything I should look for or be aware of? Any advice?:D
   / New Holland 461 haybine #2
If you dont get anything here try 'implement alley' on ytmag. Theres usually a good amt of info on most things there. If not ask and I sure someone will answer.
   / New Holland 461 haybine #3
Well you could take a 479 and cut 2' out of the center. That would give you a 7' mower. It would take about 1.5 less hp to run it over the 479, but that's your call. I've seen guys do this after hanging it up on a stone (boulder actually).
Still won't fit in your car garage, if that's what you were thinkin'....
Another thing I've seen that impressed me was to hang just the header off the front end loader frame and run it hydraulically. That takes some heft because of the weight. With a quick-attach interface , that would be a very practical set up for the right weight of a modern tractor with the right hydraulic system.
   / New Holland 461 haybine #4
Hmm, hanging it off the front. That is a neat idea... I don't like the hydraulics part but the front mount...
   / New Holland 461 haybine #5
Well you have to powerup the gearbox for the reel, rollers, and wobble drive. To do this in the simplest fashion, run hoses out to it. Hand the motor off the end of the main drive gearbox. The hoses go nicely along the loader frame.
Then you have the poor man's version of a 1461, 1479, or 1499 mower conditioner.
2021 MACDON C3812 LOT NUMBER 222 (A53084)
2021 MACDON C3812...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Kuhn FC 4000 RG (A50123)
Kuhn FC 4000 RG...
2020 FREIGHTLINER 26' BOX TRUCK (A51247)
2020 FREIGHTLINER...
