New Holland 3010
   / New Holland 3010 #1
jrtyer
palestine tx
new holland 3010
My New Holland 3010 has a front end loader, the problem that i am having is that when going up the tractor vibrates. Just started after the tractor had set up for a couple months. The tractor has 400 hrs on it
   / New Holland 3010 #2
Can you explain what you mean with a little more detail.
Is the engine losing rpm?
Is the loader jerky?
Unplug your QD's and reset them.
Have you checked all the mechanical's, such as pins, bucket alignment, straight cyl rods, etc.
   / New Holland 3010 #3
You may have only 400 hrs, but that tractor is still 12 or more years old. If you haven't changed the hydraulic filter in a while, this may be a good time. Probably no fun to access behind the loader frame, but I'd suggest you also replace the hose clamps on the suction hose just before the filter base. You could try to tighten the existing clamps, but my experience with the cheap factory units is that a thick coat fo factory paint combined with a bit of age leaves them difficult, at best, to adjust very effectively.
   / New Holland 3010 #4
Check your hyd pressure with a 3000 psi hyd gage. About $30
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A51039)
2022 Quick Attach...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
