Loader New Holland 240TL Quick Attach Bucket won't come off! Help!!
   / New Holland 240TL Quick Attach Bucket won't come off! Help!! #1
obliqueridge
Goldendale WA
New Holland TC29DA
Hi Guys
:newhere:We are trying to get the Quick Attach Bucket off out 240TL FEL but we can't seem to get it off. There are the two levers that you pull up, the one on the left comes up, but the one on the right doesn't come up all the way.:confused3: Could there by something stuck in there keeping it from coming all the way?
Thanks.
olliqueridge
   / New Holland 240TL Quick Attach Bucket won't come off! Help!! #2
Make sure there is nothing stuck, like a rock, where the pins stick out the bottom of the QA plate on your bucket. Here are pics of the loader QA showing where the pins come out the bottom and one showing the pins in the plate. Might also shoot some grease in the fittings to lube it all up.
Yeah I will try that when its not dark and I can see under there.:)
Thanks,
Obliqueridge
   / New Holland 240TL Quick Attach Bucket won't come off! Help!! #4
I keep a 1' section of 1-1/2" pipe behind my seat so I can use it as a cheater when needed. Some implements are much harder to attach than others. Getting the attachment centered exactly on the QA paddles (side-to-side) helps ensure the pins don't rub against the sides of the slots. If you have repeated problems on one implement, you may find that filing the edge of the slots a tiny bit will make attachment easier. Most times, my QA levers work with just hand pressure, but now-and-again I have to use the cheater.
OK i will get out there and try that.
Thanks.
obliqueridge
Yeah its off :)
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2006 International 9400i (A52748)
2006 International...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
