New Holland 2005 TZ25DA fires up but won't stay running
   / New Holland 2005 TZ25DA fires up but won't stay running #1
langmot
Overland Park, Kansas
TZ 25 DA
Hello, my 2005 TZ25DA has 676 hours on it. Bought new. Last fall put in fresh fuel, changed secondary filter. Primary filter changed several years ago at about 380 hours. Tractor used this past winter for several snow removals and today started fine, running well and then died. Tried restarting and engine fired, but would not stay running. Acted like it was starving for fuel. Engine shaking and dies. Unfortunately loader is attached. Any suggestions appreciated on the starting/running problem and how to remove the loader when engine won't run, to get at the engine area etc. Thanks. Tom
   / New Holland 2005 TZ25DA fires up but won't stay running #2
Crud in the bottom of the fuel tank blocking the flow? Just a guess.
   / New Holland 2005 TZ25DA fires up but won't stay running #3
Time to change that primary filter again would be another guess. Fuel starvation possibility and a "several year old" primary filter???
   / New Holland 2005 TZ25DA fires up but won't stay running #4
I agree, change the fuel filters, that’s it 9 out of 10 times. Next would be to check that the fuel pump is running. It often makes a clicking sound if you turn the key on but don’t start it.
   / New Holland 2005 TZ25DA fires up but won't stay running #5
Can you see anything but clean fuel in filter housing?
   / New Holland 2005 TZ25DA fires up but won't stay running #6
Check the air filter for a mouse nest.
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
