New Holland 1925
/ New Holland 1925 #1
dinoedwards
kubota
I don't need much of a tractor, just around the home 5 acres clearing a little brush hog, 25hrs a year.
Found this one for under 8k, thoughts.
I know it's older and bucket is pinned and bent.
I know about Tstat removal for over heating but overall thoughts with 1500hrs Hydo drive?
How hard is it to fit inverter for FEL? I guess just match flow rate?
/ New Holland 1925 #2
For the money not a bad deal for 34HP tractor. It has seen some rough treatment - no headlights, front grill upside down, but if everything works and no odd noises or mechanical issues or hydraulic, leaks etc. its worth it.
If you clean it up and put a new bucket or add a QA setup bucket it would be a decent machine.
Don't understand what you mean by "inverter" for FEL - not familiar with that term or option?
/ New Holland 1925
Sorry, 3rd function/diverter valve for possible Add a Grapple atop the bucket.
These look like 1st gen then TC, Boomer and now Work Master.
Guessing size equal to JD 955 in it's day?
Thanks
/ New Holland 1925 #5
I had a New Holland 1925, and it was a real nice tractor. I think you could buy a couple of rectangular LED lights on Amazon that would fit in the grill well enough.
Is the bottom of the bucket straight?
Why was it overheating?
Did it ever get real hot?
Does it run in the middle range without a thermostat?
If it is mechanically sound, that's a good price for a pretty capable tractor.
/ New Holland 1925 #6
I'm guessing you are thinking about this Add A Grapple
You would need a diverter and a 3rd function valve if you don't have a rear remote. It would probably work best if you had a tooth bar on your bucket.
/ New Holland 1925 #7
If you are looking for a grapple primarily to move brush, it would be a lot cheaper to buy clamp on debris forks.
/ New Holland 1925 #8
Or, make your own,
/ New Holland 1925 #9
You can add a third function pretty easily - $600-1000 - WR Long makes a good kit, I installed one on my B21 last summer, and a QA conversion which opens up more options like forks and grapples etc.
Or if you just add the grapple to and straighten out the existing bucket and the 3rd function would be a lot less.
/ New Holland 1925
Which one would u buy TC33D or 1925?
Both Hydro, same hrs 1500each, price is 14k for package deal TC33D or $7800 for 1925? Believe this are the same just different Gen.
/ New Holland 1925 #11
It depends 100% on a full understanding of this
... I know about Tstat removal for over heating but overall thoughts with 1500hrs Hydo drive? ...
/ New Holland 1925 #12
I bought my 1925 new back in Sept 1998. It is 34hp and HST 4x4 with 1325hrs on it. I changed out the bucket and put a WR Long 4-n-1 bucket on it and it has a diverter valve mounted on it. I take care of my equipment and keep it stored in garage or covered up if outside. I change the engine and hydraulic fluid annually with the filters of course. I absolutely love this tractor. I've had a few issues with it over time but that is to be expected.
