New Holland 1920 engaging high gears
   / New Holland 1920 engaging high gears #1
mjp2000
New Holland 1920
Our new holland 1920 is working just fine in medium and low but doesn't seem to engage in high gears. The pto works just fine. I've adjusted the clutch as it had little play in it but high seems to be the problem. It has worked every once in a while especially after adjusting the clutch but it doesn't work for long.
   / New Holland 1920 engaging high gears #2
I believe your not adjusting your clutch properly. The clutch pedal should have 3/4" - 1-1/4" of play.
Taking the play out of the adjustment will eventually allow the clutch to slip.
Mike
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2020 FREIGHTLINER...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
2014 International Bucket (A55973)
2014 International...
Toro (A56857)
Toro (A56857)
