New Holland 1920 engaging high gears
   / New Holland 1920 engaging high gears #1
mjp2000
New Holland 1920
Our new holland 1920 is working just fine in medium and low but doesn't seem to engage in high gears. The pto works just fine. I've adjusted the clutch as it had little play in it but high seems to be the problem. It has worked every once in a while especially after adjusting the clutch but it doesn't work for long.
   / New Holland 1920 engaging high gears #2
I believe your not adjusting your clutch properly. The clutch pedal should have 3/4" - 1-1/4" of play.
Taking the play out of the adjustment will eventually allow the clutch to slip.
Mike
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
