New Holland 1720 Question?
   / New Holland 1720 Question? #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I have a 1720 with 32XX Hrs It starts and runs very well but smokes more than I'd like it to. Would a valve adjustment help or what would suggest?
   / New Holland 1720 Question? #2
Is the smoke black? It could be excess fuel, having the injectors tested would be pretty easy to do.
   / New Holland 1720 Question? #3
How long has it been smoking, is this a new symptom?
Is it blue, black or white smoke?
Does it smoke under full power. Some more details will be helpfull.
How long have you owned it?
I have only owned the tractor about 7 months. It has a short blast of black smoke on start up but that is normal. aftre it runs a while its hard to see anything unless you rev it up a little. At nite you can see it with the headlights on. It may be nothing to worry about but it does get a bad exhaust smell. I'll have the injectors checked, it may be too rich.
   / New Holland 1720 Question? #5
I've had my 1720 for 15 years & put 1800 hours on it. Your observations sound normal.
Starting would generally be an issue if there were injector or mechanical problems.
Older diesels smoke especially during acceleration & heavy load.
I'd run it.
   / New Holland 1720 Question? #6
Same here with mine...
I have around 500 hours give or take and when cranking get black smoke...
Clears right up when warmed up...
   / New Holland 1720 Question? #7
It will do no harm to check and adjust the valves if they need it.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2018 Ford F150 4x4 Pickup Truck (A51692)
2018 Ford F150 4x4...
