New Holland 1720 Question?
   / New Holland 1720 Question? #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I have a 1720 with 32XX Hrs It starts and runs very well but smokes more than I'd like it to. Would a valve adjustment help or what would suggest?
   / New Holland 1720 Question? #2
Is the smoke black? It could be excess fuel, having the injectors tested would be pretty easy to do.
   / New Holland 1720 Question? #3
How long has it been smoking, is this a new symptom?
Is it blue, black or white smoke?
Does it smoke under full power. Some more details will be helpfull.
How long have you owned it?
I have only owned the tractor about 7 months. It has a short blast of black smoke on start up but that is normal. aftre it runs a while its hard to see anything unless you rev it up a little. At nite you can see it with the headlights on. It may be nothing to worry about but it does get a bad exhaust smell. I'll have the injectors checked, it may be too rich.
   / New Holland 1720 Question? #5
I've had my 1720 for 15 years & put 1800 hours on it. Your observations sound normal.
Starting would generally be an issue if there were injector or mechanical problems.
Older diesels smoke especially during acceleration & heavy load.
I'd run it.
   / New Holland 1720 Question? #6
Same here with mine...
I have around 500 hours give or take and when cranking get black smoke...
Clears right up when warmed up...
   / New Holland 1720 Question? #7
It will do no harm to check and adjust the valves if they need it.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Bud Dry Neon Sign (A50123)
Bud Dry Neon Sign...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
