New Holland 1630 loader whine/jumpy hydraulic problem
   / New Holland 1630 loader whine/jumpy hydraulic problem #1
Jtracker
Sandusky ohio
New Holland 1630
Hello everyone,
I just purchased a 1998 New Holland 1630 HST 4wd tractor with 7308 loader w/720 hours. When I try to lift the loader it makes a loud whining/squealing noise and the loader goes up but it is very slow & jumpy. I checked the fluid & it is at the full line when cold & the fluid doesnt look dirty or milky. I have taken the bypass valve out of the joystick controls & the manifold diverter block, cleaned them and reinstalled with no difference. Not sure how to check if one of the bypass valves are bad? I was also wondering if there is a screen or screens somewhere I can check to see if clogged? I dont have a manual yet as original owner hasn't found them yet. I have also tried switching the quick connect hoses thinking maybe the previous owner hooked them up incorrectly but still no difference. The previous owner told me he blew a hydraulic line, drove it into his shop while leaking fluid the entire way maybe 500ft. He replaced the line and then this problem started happening. He replaced the filters & fluid last July and it has been sitting since. I was going to replace the filters and fluid but since he just did it before parking it, I was wondering if there was some other things I could try before spending over $200 on filters and hydraulic fluid. The loader will go all the way up and the bucket will also curl but as stated just very slowly and jumpy. The 3 point hitch does the same thing when raised. I am mechanically inclined but haven't worked on many hydraulic systems. I'm assuming I need to get a hydraulic gauge and test for pressure. I have been reading the forums here and others pointed me to tractorbynet because it is such a great forum. Any and all help is appreciated! Sorry for the lengthy post. I have included a video of the noise and what it is doing. Thanks so much!
New Holland 163 loader whine/squeal - YouTube
   / New Holland 1630 loader whine/jumpy hydraulic problem #4
Hello everyone,
Please add your location to your profile.
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
Quick Attach Pallet Forks (A47384)
Quick Attach...
