New Holland 1469 Haybine... good machine?
   / New Holland 1469 Haybine... good machine? #1
whitmerlegacyfarm
Central PA
2010 Kioti DK50SE HST w/ 401 Loader
Ok guys you all have been a great help in me getting all my equipment. I got another smoking deal on a Nh 1469 haybine. Rollers look brand new and cutter bar looks perfect new knives just little rusted over from sitting in barn for 2 yrs. This has the Wisconsin Motor. We had not luck getting it to start but didn't have any tools or starter fluid. Was cranking good. Im not mechanically inclined but i can get this for 500 bucks. Im going to have to pay my local ag dealer to haul it home for me though. I have no way of getting this thing home. My neighbor who i will be helping makes hay says he know all about these Wisonsin motors cause his Skid Steer has one in it. My question is..
How are these units on slopes being hydraulic? I'm just very small operation but for 500 bucks i'm thinkin with shape of the haybine minus what motor might need done to it, it's probablly worth $1500 atleast once it's running. I'm hoping i can get my local ag dealer to haul it for like 200 bucks or so. It's out 70-80 mi round trip.
Just wanted to see what everyone's takes are on these self propelled haybines? It's just the 2 joysticks for steering doesn't have steering wheel column like newer models i guess. I honestly don't know about them. All this farming and haying is new to me.
Thanks all
   / New Holland 1469 Haybine... good machine? #2
DON'T use starter fluid. You could (or will) ruin the motor if you don't know what you are doing. Instead, see if there is spark, if not, then get spark by fixing the ignition system. Then see if there is any gas getting to the plugs. If not, then find out why. If you have some experience, then dribble a teaspoon of gas down the carb venturi to see if it will fire. I've used WD-40 spray (3 seconds worth) to help a dry motor start.
Check for rotted hydraulic hoses, wobble box grease, hydraulic oil levels, tire pressure, knife teeth, stone guards, hold down clips, roll chains, reel drive belt, sickle drive belt, radiator hoses and stick joint lubrication. Clean the windows in the cab, too. There is almost always dried mud, haylage, cow poop and oil fim on them. If it doesn't have a rear view mirror, add one.
I love to run a 1495. The way the reel teeth cycle is hypnotizing.
You can see all the parts and repair diagrams for this machine on the New Holland website.
   / New Holland 1469 Haybine... good machine? #3
Maybe something resoneable. If nothing else you could get most of your money back out of it just as scrap.
If the rollers are good, new, or at least solid and not delaminating that is half the battle with haybines. It sounds like it may be worth a shot anyway.
Realy? It has no steering wheel just 2 levers for steering. I duno just curious. It has a single dolly wheel in back. My neighbor says he will hav no problem gettin motor runnin. Im concerned if I can run on up n down hills with this machine.
   / New Holland 1469 Haybine... good machine? #6
You will have a learning curve to go through, but as long as they are not too step, you should be able to do hills, not mountains or cliffs. All differential steering started out as mechanical systems on the early track machines. In some instances the handles were the clutches, and you had individual foot brakes to make the turns tighter. Does that machine have a gear shift and foot brakes, or is it variable speed from the sticks?
To b honest I dont know. There is 2 steering levers n one foot petal to the left of steering levers.
Ok guys sounds like haybine is mine for 500 bucks. Goin to cost me like 200 to get it hauled. Im very excited this should b awesome to use next year. I will b getting it monday or tuesday.
Pickin up 1469 tomorrow morning. Hopfully will get some pics n let ya know when we get her runnin.
   / New Holland 1469 Haybine... good machine? #10
The 1469 is a great machine, cut many acres with it. This is powered by hydrostatic motors, push forward on the joysticks to move forward and pull back to move in reverse. Speed is controlled by the foot pedal which controls a hydraulic activated variable speed belt. This is very easy to control once you get used to it. Probably will want to put new hydraulic oil in the hydrostatic system as this is an old model unless you know when it was changed last.
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2004 Mack CV713 Granite Fuel and Lube Truck (A51692)
2004 Mack CV713...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
