NEW HERE
/ NEW HERE #1
CAVEMANN
Ajo
BOLENS G14
I'm Jeff from southern Arizona, don't currently own a tractor but would like a compact or slightly larger for use on our 2 1/2 acres.
/ NEW HERE #2
Welcome Jeff, glad to have you aboard. I live on 2.3 acres and have several tractors, so watch out, it is addicting!!
David from jax
/ NEW HERE #3
Welcome to the forum! My retired FIL has a JD 3038e on his 2 acres and it's just perfect for him. He uses it every day for tending his many flower gardens, vegetable plot, turning his compost pile, plowing snow, etc.. He never runs it over idle speed but in the spring and fall he lets me use it to mow, move brush piles and logs around at my moms 40 acre estate and I blow the soot out of it for him.
/ NEW HERE #4
:welcome:
Welcome to the forum! You've come to a good place for tractor info. :tractor:
/ NEW HERE #5
Welcome CAVEMANN!
mcfarmall, glad someone is running at different RPMs. Guessing you will slow down someday too though. It sucks. :laughing:
/ NEW HERE #7
Welcome, we love to help people purchase tractors!
/ NEW HERE #8
:welcome: to TBN...enjoy.
/ NEW HERE #10
The best way to shop for tractors is to list your tasks first, then determine how much bare tractor weight you need to SAFELY accomplish your tasks. Bare tractor weight is a tractor specification easily found in sales brochures and web sites.
For most tasks greater tractor chassis weight is more important than tractor horsepower. This tractor fundamental is difficult for people new to tractors to comprehend.
Heavier tractors have more tractive power pulling ground contact implements. Greater mass of heavy-chassis tractors increases tractor stability when transporting loads in the FEL bucket, the most rollover prone of routine tractor tasks. Heavier tractors have larger wheels and tires better able to bridge holes, ruts and downed tree limbs, yielding a smoother, less disturbing passage over rough ground.
Safe hillside operation demands more tractor weight than flat land operation. Heavier tractors have wider wheel spreads making them less laterally unstable. Rear wheel spreads may be decreased or increased.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Tractors under 3,000 pounds bare weight are offered in one configuration. Most, such as the high volume kubota standard L series, are sparely equipped to hit competitive price points. Others, such as the Yanmar YT235 and Kubota B2650/B3350 series, include enhanced productivity and comfort components.
Most tractors under 3,000 pounds bare weight are operated in residential applications on one to five fairly flat acres. These "residential tractors" fit in a typical garage.
Tractors over 3,000 pounds bare weight are generally offered in a utilitarian configuration and a deluxe configuration, on a common chassis. Deluxe kit enhances productivity and operating comfort ~~~ but you have to pay. Many tractors over 3,000 pounds bare weight are too tall to fit in a typical garage, even with ROPS folded.
It takes a 50% increase in tractor weight before you notice a significant tractor capability increase. It takes a 100% increase in tractor weight to elicit MY-OH-MY!
Selling a used tractor is easy. Selling light implements in order to buy heavier, wider, implements for a heavier tractor you take a hit in depreciation. Passing time with multiple browsers is a pain. ((Ask me how I know.))
For most new to tractors a quality dealer, reasonably close, available for coaching, is important. Dealer proximity is less important to others, well experienced with tractors, who perform their own maintenance. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment.
Horsepower is a primary consideration only operating PTO powered implements.
BUY ENOUGH TRACTOR.​
