new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
So I can get a mx5100 with backhoe for 37000 or a 60hp jd4520 for 5000 more ...is it worth the money in your opinions..advice and opinions appreciated
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #2
its a no brainer for me id go with the kubota an save the $5000.because i doubt if JD will meet kubotas price.
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #3
Mainly depends on your uses. For me those are both "borderline" machines... A 50HP would be too large to fit where I need it to, or too small to power the implements I need powered in the places they need to go. A 60 would likely power the larger implements the places I need them to go, but there's no way it could fulfill the small tasks I have. For my uses a 40 and a 80 are the ideal combination of machines. One day as I age I may like a small 30HP unit to tend to small tasks, but I doubt it.
Best bet is create a list of chores you need the machine to fulfill and purchase accordingly.
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #4
As others have said, we need to know what you are going to do with the tractor before we can help guide you.
Mostly timber work..hauling firewood...digging out stumps, tilling up smaller food plots and gardens...but like I said, mostly timber work
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #6
The 4520 is to really comparable to a MX5100. A L5740 or L6060 would be comparable to the 4520. Does the 4520 have a loader and backhoe?
These are both compact tractors similar in size to yours.
Yes it does
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #8
I was cutting my size requirements close with what I have. Anything any larger wouldn't have fit. Tight space requirements was also why HST was a requirement for me. I didn't look at those models specifically, but all the 50s and 60s I've had under me have measured larger, even if only slightly. Turns out there are a couple places I can't get my 4035 without taking out a couple trees I'd rather leave, so even slightly larger is too large...
   / new here..what will i notice between a 50 hp to a 60hp?? jd vs kubota #9
Yes it does
The 4520 is more of a deluxe/ premuim tractor than the MX5100. They are both nice tractors. If you can live with out all the fancy features the MX5100 may be the way to go. I think you should look at a Grand L Kubota. It is in the same class of tractors as the 4520.
2018 Land Rover (A53424)
2018 Land Rover...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
