new here and a to me Omc Mustang 440 loader
   / new here and a to me Omc Mustang 440 loader #1
aasrs
NE GA
OMC Mustang 440
Hello, I'm tom, just found your website looking around for operating information on a omc mustang 440 with a Wisconsin engine I just bought
it has a couple issues, needs a ring gear on flywheel, has a leak in one steel line up front, and the belt that needs replaced badly, it also does not stop when the levers are in the "neutral" position,
so I look forward to doing some searching about and learning some more about this little loader
Tom
here is a thread i posted about the machine in so far
http://www.tractorbynet.com/forums/showthread.php?t=302459&referrerid=241014
   / new here and a to me Omc Mustang 440 loader #2
Welcome from Wisconsin
thanks!
   / new here and a to me Omc Mustang 440 loader #4
Tom,
Some info here that may help in finding information & parts. OMC (Owatonna Manufacturing Co.) built skid-loaders for a number of years for john Deere. If your 440 has 2 steering levers (left & right) then it is clutch controlled with variable speed belt driven, exactly the same as a JD24. If your 440 has single lever T bar control it is hydrostatic drive and is same as a JD24A with exception of the engine. JD had OMC build the JD machines with liquid cooled Continental engines but everything else on machines is identical.
thank you Dennis!
tom
   / new here and a to me Omc Mustang 440 loader #6
G'day and welcome to TBN from Downunder.
Enjoy the site... and it looks like it's already happening.
:welcome:
thanks for the welcomes!
been working on it as much as I can, new drive belt is on, one hydraulic leak repaired in a metal line, right side clutches are adjusted, need to adjust the chainsm but flywheel was a complete failure today, could not get it off...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
3in Poly Pipe (A49461)
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
