new here and a to me Omc Mustang 440 loader
   / new here and a to me Omc Mustang 440 loader #1
aasrs
NE GA
OMC Mustang 440
Hello, I'm tom, just found your website looking around for operating information on a omc mustang 440 with a Wisconsin engine I just bought
it has a couple issues, needs a ring gear on flywheel, has a leak in one steel line up front, and the belt that needs replaced badly, it also does not stop when the levers are in the "neutral" position,
so I look forward to doing some searching about and learning some more about this little loader
Tom
here is a thread i posted about the machine in so far
http://www.tractorbynet.com/forums/showthread.php?t=302459&referrerid=241014
   / new here and a to me Omc Mustang 440 loader #2
Welcome from Wisconsin
thanks!
   / new here and a to me Omc Mustang 440 loader #4
Tom,
Some info here that may help in finding information & parts. OMC (Owatonna Manufacturing Co.) built skid-loaders for a number of years for john Deere. If your 440 has 2 steering levers (left & right) then it is clutch controlled with variable speed belt driven, exactly the same as a JD24. If your 440 has single lever T bar control it is hydrostatic drive and is same as a JD24A with exception of the engine. JD had OMC build the JD machines with liquid cooled Continental engines but everything else on machines is identical.
thank you Dennis!
tom
   / new here and a to me Omc Mustang 440 loader #6
G'day and welcome to TBN from Downunder.
Enjoy the site... and it looks like it's already happening.
:welcome:
thanks for the welcomes!
been working on it as much as I can, new drive belt is on, one hydraulic leak repaired in a metal line, right side clutches are adjusted, need to adjust the chainsm but flywheel was a complete failure today, could not get it off...
2012 Ford F-150 Crew Cab Pickup Truck (A55788)
2012 Ford F-150...
Safety Basket (A53316)
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2002 Ford F-150...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
