SteinerGuy
Gents,
Long time reader, first-time poster.
We live in hilly terrain and mowing with my old lawn tractor was always a white-knuckle affair. While my other tractor, a Lamborghini Runner 450, would climb the side of a house if it had to, it's too heavy to drive over the septic system and on ag tires, it sure tears up turf, so that was out.
So, I started looking at several options and I found out about Ventrac and Steiner. I used to own a Pasquali 988, an articulated italian tractor, so I knew how handy an equal-wheel 4x4 artic tractor is, and how much tractive force they can put to the ground.
After looking around for a couple of months, I bought a rough and ragged Steiner S-20 with a blade and a 60" mower deck. Beat is an understatement. I'm slowly going through everything, rewired it, fixed a lot of bad welding, etc. Nothing too bad so far.
So, enough background - The issue at hand:
I got it running and mowing a while ago, and I tried "the hill", which is a very steep section I have always mowed downhill with conventional mowers. To my dismay, it struggled. The pump whined and I had to push very hard on the lever to keep it moving, and it finally stalled out completely, it would not move. I was a bit disappointed, figuring that the pump probably needs a rebuild.
And on we went, mowing downhill, not a huge impediment. Until today, where I tried backing up, as a fluke, and the darn thing walked up the incline like it wasn't even there, the back tires barely touching the ground.
Now, I've been racking my brain to try and figure out what's going on. The S-20 pulls fluid from the front axle, so it should run out of oil backing uphill, not driving uphill. I don't think the pump could work better in one direction than another, I figure if the pump elements are good enough to work in reverse, they should work in forward...
Any comments from you Steiner experts? Fluid level was, as near as I can tell, correct. Hydraulics seem to work well, it picks up the deck without any issues and the steering is strong (but it has trouble steering if you drive uphill, seems to steer better if you back uphill...)
I are confused!
Cheers,
Steiner Guy...
I are confused!
Cheers,
Steiner Guy...
