Comparison New guy looking for advice
   / New guy looking for advice #11
riding lawn mowers even garden tractors and even the more expensive riding lawn mowers that are a bit bigger. they will beat you to death. (no suspension, dust clouds, slow MPH mowing, and then upkeep of repairs on them). you need something to mow with. but you need something big enough to get it done. if not you can kiss 6 to 8 hours a week goodbye just mowing. its all fine and dandy, but it eats up money for a larger tractor, that gets it done quicker, and hopefully less maintance due to not needing to drive it a full day each week in spring/summer/fall.
2 wheel rear drive tractor. used, can be had for fairly cheap. yes they are heavier, and they are bigger. and you will need to wait a little bit more before you get them out on the grass to mow without leaving ruts. but they get the job done, so you can enjoy it vs a struggle just barely maintaining it with a riding lawn mower.
there use to be a tag team of 2 riding lawn mowers for this farm when i was young. this farm, plus uncle, plus grandpa home all together. to mow it all. and it would beat everyone up.
old allis chalmers B,or C, or CA with a belly or rear mower can make for a nice old tractor, takes some learning dealing with there quirks, and making sure you keep them oiled, greased, and taken care of. but much easier to use.
25 to 35 HP most likely what you will want, 40HP most likely pushing you over the top and 40HP being a bit to big for using as a regular lawn mower for around the home itself.
25 to 35 gets you in the CAT 1 3pt hitch, allowing you to get that rotatory cutter, which you can find used on craiglist and tractor house and local newspapers. does not matter if they are old are not, most of them should still be kicking with life in them. see about making sure tractor comes with either a belly mower or a 3pt hitch finishing mower, these can be a bit expensive even used.
what ever tractor you get, buy the service/shop manual for it. so you have a descent manual to trouble shoot from. and not spending away cash trying to figure out whats wrong with it.
Thank you for the honest advice. I will be looking for something a bit bigger than my original plan. We do have other aspirations besides cutting grass all weekend so I will have to go bigger.
Are there brands of the older models I should avoid?
Thanks again!
   / New guy looking for advice #13
How much money do you plan on spending on a tractor? This can help folks on here give you an idea of what kind of tractors are out there that fit your price range.
Mitsubishi MT 372 Diesel Compact Tractor what about something like that? Is Mitsubishi any good? My max right for the tractor and a mower whether it be bush hog or finish mower is 3500. I know it'll be old but I do like tinkering and figuring stuff out.
   / New guy looking for advice #15
1952 Allis Chalmers B Tractor w/mower deck around me these old allis chalmers go around 2000 to 3000 with belly mower
Ford 9n Tractor 1941 ford 9n old tractor
1954 Farmall Tractor with woods deck
1974 574 international tractor most likely a bit to much for just mowing as in being able to easily pull off FEL
narrow front tires (tri cycle in thought) can be nice more so with split rear brakes (brake peddle for left rear tire, and brake peddle for right rear tire), lets you turn quicker and tighter to point of spinning on a dime. allis chalmers CA 1954 tractor, is what i have, no power steering, but it gets in and around trees to reduce trimming amount, much like a zero turn mower.
a lot of old tractors in your area. typing in $300 min, $5000 max there is nothing to stay away from for "brands/make/model" when buying used. it is... is the machine in good mechanical condition, it may look like a rust bucket, but start up and run like new. with old tractors you need to get out and test drive each one. and test drive a few of them. no if's and's or but's. this will give you experience to see different types of tractors, power each one has, how they turn, how they operate, and give you some idea of run away from as fast as possible due to engine issues, to many leaks, mechanical issues, etc....
have had to step into deep end and learn how to work on old tractors. not fun at times. but do what you gotta do.
Thanks! I will take a look at those and get an idea what I should be looking at.
   / New guy looking for advice #17
Look at an M Farmall or a Ford 8N both great tractors lots of them out there and for not too much money
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
DEUTZ MARATHON...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JLG 1255 Telehandler (A55315)
JLG 1255...
