new guy from SE PA
   / new guy from SE PA #1
Roots
JD 750 MFWD
Hi All.
after a few months of searching, I bought my first CUT; a mid-80's JD 750 MFWD, with 60 series MMM and 70 series FEL. I've been pretty happy with my machine so far, and look forward to learning everything I can about it.
I've been using it to cut grass around the property (2.5 ac.), and move "stuff" (mulch, wood, etc.) Look forward to moving some snow this winter (although if we get no snow I'll be happy too)!
Cheers,
Eric.
   / new guy from SE PA #7
Welcome to TBN!!
I think that 750 will get a good work out this winter. If we continue to get the precipitation we've gotten this spring and summer, we're likely to have a lot of snow.
BTW, if you're considering chains for your tractor, order them now! They might not be available later this year. Try www.tirechains.com
Thanks for the welcome everybody!
Roy, without knowing a whole lot about plowing a driveway with this tractor, do you really think chains are called for? The tractor is equipped with ag tires and weighs close to 2,000lbs without considering the loader. I hadn't considered chains, as I had assumed that the weight of the tractor, the fact that it is MFWD and has ag tires all around would be sufficient to handle my 200' driveway.
BTW, thanks for the link.
Eric.
   / new guy from SE PA #9
Eric.
Hi Eric!
I'm in southern York County...probably not too too far from you. So, we probably see about the same amount of snow.
I got by without chains for about 8 years. However, 5 or 6 of those years (2003-2007 or 2008) had very little snow. Anyway, I did pretty good without chains on bar turfs (first two years) then Industrials. Now, I did get stuck on occasion and had to use the loader to push me out or a bit of shoveling.
Then the double-whammy of Feb 2010 hit (two 15+ inch storms within a few days of one another) which I'm sure you remember well. That was a lot of snow!!
Anyway, after getting stuck numerous times, I decided chains were in my best interest. So did everyone else, unfortunately...no chains available (15-19.5 Industrial tires are very commonly used...I'd wager the majority of mid-sized CUTs use this size R-4).
During the late Spring, I traded the 790 (with the R-4's) for a 4400 with turfs. I'm sure the tractor would do fine with no chains for most snows (which are 6" or less around here), but wouldn't do so well in greater accumulations...especially if we get another major storm or storms. So, I bought chains (4 Link ladder style since my drive is level and hard packed gravel).
I install the chains after the last mowing of the year (late Oct or no later then mid-November). I have no interest in struggling with chains in the midst of a blizzard.
Although we didn't get a lot of snow last winter, the chains did quite well. I have them on the rear tires only and didn't need MFWD much at all. I did get a lot of practice using the steering brakes though.
How will you do with those Ag tires? Well, can't hurt to try them without chains for a winter or two, then make your decision. I got by for quite a while without them.
My comment in that post applied if you were planning on getting chains, order them early.
24FT Enclosed Trailer (A53424)
24FT Enclosed...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
JMR stump/trenching bucket (A53421)
JMR...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
