Grapple New grapple and toothbar
   / New grapple and toothbar #1
rfmr
NH
Kioti CK30HST
My dealer just returned my LB1914 after installing an ATI GK4866 grapple and TBC-70 toothbar.
First time attaching pictures so I hope it works.
   / New grapple and toothbar #2
That's a nice looking setup you have there! If it were me, I'd be afraid to use it, it looks so good! Bet you have a lot of fun with that.
   / New grapple and toothbar #4
Approximately how much weight did all that plus plumbing add to your bucket?
Did the dealer install a new valve for the grapple attachment? New control? Diverter? What method?
Thanks,
According to ATI specs, the grapple is 137 lbs and the toothbar is 47 lbs. Both are bolted on so they can be removed (Grapple - 4 bolts each side, Toothbar - 1 bolt each side). Grapple has seperate lever control tapped into and mounted beside the hydraulic control for the bucket. Hoses are quick disconnect.
   / New grapple and toothbar #6
That sounds like a great set-up.
You should be very happy with it. I don't have the grapple yet (in transit as we speak) but I've had the toothbar for quite a while and it's made a huge difference in digging and moving/popping brush and small trees.
   / New grapple and toothbar #7
Very nice looking setup. I also believe that if you look closer at your setup you can most likely pull the pins holding the cylinder and the lift arms and quickly pull them leaving the support tube on the bucket. I do it whenever I'm working in the dirt, it's quick and easy 5 minutes tops.
   / New grapple and toothbar #8
Nice looking rig!!
2015 C&M TRAILER INC 14 ENCLOSED CARGO TRAILER (A55745)
2015 C&M TRAILER...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A55852)
2018 Freightliner...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55314)
2008 Ford F-250...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
