New grab hook bar added to bucket
   / New grab hook bar added to bucket #11
As far as I am aware, there is no such thing as grade 8 lock washers. Bolts are graded by tensile strength, but lock washers are all the same regardless of the grade of bolt application. To me, nothing beats a double nut for locking a nut in place on a thru bolt
I disagree... almost ALL bolt suppliers (Doorman, Fastenal, Home Depot, Lowe's) offer grade 8 lock washers.
Do a google search and you'll find many references to grade 8 lock washers.
   / New grab hook bar added to bucket #13
I would use some never sieze and,a regular washer and nylock nuts.
Looks good
   / New grab hook bar added to bucket #14
A drop of blue locktite and forget it. Edit: on second thought, rust prone environment I second anti-seize and a jam nut or lock washer.
This may seem strange to you guys but, besides being a locking compound, Loctite also works as an anti-seize. It seals the air and water out of the bolt threads keeping them clean and shiny!
   / New grab hook bar added to bucket #15
Darn I like that--very nice!!!
Woodsman
Thanks Woodsman,
I have used it a few times and the hooks have worked out great. the rings stay out of the way when you load fire wood in the bucket.
Damien
   / New grab hook bar added to bucket #17
Nice looking welds. I did the same thing on my tractor but used channel instead of flat bar. Just a friendly suggestion would be to add some type of vertical strength because I have slightly bent the top of my bucket even with the channel. I will admit I abuse the receiver by rolling the bucket with a chain pulling large logs. My channel is stitch welded to the top of the bucket. Your flat bar is adding little strength preventing bowing the top. Just trying to help you out before you bend your nice looking bucket.
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
utv cart Honda (A56857)
utv cart Honda...
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
