New Goose Neck
/ New Goose Neck #1
Jimbrown
Tombstone Az
KIOTI LK30
I got these in an email. At first I thought it was a joke but after looking at #3 I am not sure.
/ New Goose Neck #2
Thats a riot:D :D :D How could any one be some numb!He should have had a weight distribution hitch and the blazer would have handled it better:p Should have called this thread the redneck 5th wheel.Prabably big momma is sleeping up in the front bunk,thats why its so heavy:D
ALAN
/ New Goose Neck #3
He should do just fine. He put an extra set of chain on the tailgate and he has the back up block of wood under the tailgate on the hitch receiver. Maybe it is over built. The biggest safety concern is his headlights will be shining into the eyes of oncoming traffic. Maybe 90 psi in the rear tires should help take care of that. ;)
He should just mount it to the roof.
/ New Goose Neck #4
I bet it would be easy to correctly align the ball and tongue when backing up to it.
/ New Goose Neck #5
Look at pic #3. It looks like the ball is way small for the reciever. But I am sure it is just my imagination because of the way the rest of it is built I am sure he has the right ball????
I can't beleive DOT would not stop him at first site.
murph
/ New Goose Neck #6
murph
Depends on which state. TN would probably let it slide :)
/ New Goose Neck #7
jeez hon.....the steering seems a tad light.....
/ New Goose Neck #8
No one mentioned the block of wood that's under the tailgate to hold it up...too funny :D
/ New Goose Neck #9
Hey, Guys! Where are your charitable comments commending innovation, welding skills, innative and championing repurposing of expensive equipment toward meeting changing needs:confused: I mean, I'm not going to comment on the photos, but will let you know that my other half, sitting at my elbow is in hysterics... shouting WRONG:eek:
/ New Goose Neck #10
like the man said "ya cain't fix stupid"
/ New Goose Neck #11
And just what's WRONG with that set-up? According to some of the stuff I've read on the trailer forum, all a guy would have to do is, drive careful, allow a little extra space for stops, make certain his tires are inflated to proper pressure, and keep speeds under 80 and that's as safe as it needs to get. (SARCASM indicator light flashing brightly)
Obviously, much effort went into the design and construction of that hitch. The wooden blocking being dowelled to the reciever drop is a brilliant touch. As well is the redundant support chains on the gate. (Take note of the high quality "s" hook on the end of that chain!) They should suitably impress any State Trooper.
/ New Goose Neck #12
If we, at our company, tried to get this onto the road in Holland, the traffic inspection agency would have the following comments:
1. any 5th wheel device should be directly mounted to the truck frame. If an additional subframe is used, you need to have a calculation report of a 3D Finite Ends Analysis (FEM) to show that the assisting construction is strong enough.
2. The center of the 5th wheel coupling is not allowed to be behind the rear axle center.
3. the log of wood supporting the tailgate is obstructing the view at the license plate
4. The trailer should clear the truck cab in 90° in both directions (left and right turns)
If all these criteria had been met, the inspectors would still find something silly to stop anything from getting on the road like this :D
/ New Goose Neck #13
Just my opinion, but in all likelyhood, a quick, on the spot "mental evaluation" of the driiver would result in a "NO GO" on this rig. ;)
/ New Goose Neck #14
Is that an ALABAMA lic plate?
/ New Goose Neck #15
Eat drink and be marry for tomorrow you may be in UTAH!!
I lived in SLC for about 10 years my mother still does. It has a lot of neat places to go and has very pretty scenery but........ most of the people there are way nuts behind the wheel. Speed limit signs are just a suggestion and it is a race from light to light and if you get on I-15 it is a plain Indy 500 (with bad drivers).:eek:
It is so bad I have to tell my mother she can not drive my vehicles when she comes to visit. She has gotten better over the years but still a Lead Foot!!
So really these pics do not surprise me one bit.:D
/ New Goose Neck #16
I can't believe you guys missed the biggest mistake in that setup. The 4X4 block should at least be a 6X6 for the added support and for sure some type of Elmer's glue to hold it in place on the ball receiver.
/ New Goose Neck #17
"The 4X4 block should at least be a 6X6 for the added support and for sure some type of Elmer's glue to hold it in place on the ball receiver."
INCORRECT! The 6X6 would not have the proper amount of damping. It is obvious that you have not studied this design. The 4X4 provides a damping element that reduces the impact stress on the assembly.
I also admire the use of the "S" hooks on the safety chains. Usability was obviously considered here. So simple to attach...
I don't see why everyone is so critical. You are just jealous of his fabrication skills. You shouldn't criticize the design until you have built your own S10 Blazer 5th wheel.
J
/ New Goose Neck #18
The 3D FEM analysis which is required by European law to get an approval on a 5th wheel subframe, has to prove that there is a safety factor of 5 near welded areas... i'm pretty sure the wood has a better fatigue strength than steel .... :D :p
/ New Goose Neck #19
I am now building my own, for my Ford Focus. Is the wood supposed to be pine or oak?
/ New Goose Neck #20
"The 3D FEM analysis which is required by European law to get an approval on a 5th wheel subframe, has to prove that there is a safety factor of 5 near welded areas... i'm pretty sure the wood has a better fatigue strength than steel ...."
That is what I'm talking about. It takes forward thinking to embrace such radical design vision. This is the way of the future- soon we will all be running around in these. Mine is going to convert quickly so I can haul livestock as well.
Shopping list:
(1) 8' 4X4
swingset chain
S hooks for said swingset chain
misc scrapyard metal
unibit for cutting "safety chain" holes in sheetmetal
(1) $500 Chevy Blazer- undoubtedly not mechanically sound w/ 0 load.
Am I missing anything?
J
DEUTZ ENGINE AIR COOLED MOTOR (A64281)
DEUTZ ENGINE AIR...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
John Deere Worksite Pro RS72 (A64119)
John Deere...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
