New GMC 2500HD 6.0 GAS Opinions
   / New GMC 2500HD 6.0 GAS Opinions #1
gamble77
Georgia
Am getting ready to purchase a new truck. I at one time had a 2003 Chevrolet 2500HD with the 6.0, I always felt like the motor had enough power but the 4-speed transmission just couldn't keep up. On the new HD's they have not only upped the power in the 6.0 engine but are now also putting the 6-speed transmission in them. Does anybody have any experience with this transmission? Any MPG figures? I don't think I can justify a diesel when you consider the extra money up front PLUS the extra money at the pump. Any advice would be appreciated.
   / New GMC 2500HD 6.0 GAS Opinions #2
Hey Nathan, if it's the Allison tranny -- can't go wrong there; IMO. Don't know alot about the 6.0l engine. My younger brother has one that he tows his 7XX Bobcat with (can't remember if it's a 5,6,7 three series.)
His hasn't missed a lick! I think he get's around 12-13mpg pullin' a good load with it.
Best of luck.
AKfish
   / New GMC 2500HD 6.0 GAS Opinions #3
I can tell you this. I have an 07 Duramax / Allison, 4x4, EC and since they added the diesel particulate filter the mileage is down. The 07 is 15.5 MPG vs. 20.5 for the 05 Duramax / Allison. Also diesel in my area is a buck more per gallon than gas. Mine is a lease so when it runs out I'll be going back to a gas truck unless they change something to improve the diesel mileage. Guy's I know with the gas trucks are in the 20 MPG range.
   / New GMC 2500HD 6.0 GAS Opinions #4
I test drove one about 2 month's ago and it felt like it had a lot more power than my '02 K2500 Suburban with the 6.0L. I researched the mpg. figures on another forum and they weren't that much better maybe 12/15. We decided on the K2500 CCSB Duramax/Allison and after 5,000 miles am seeing about 12/19. The 6.0L/4L80E used to try and overheat when pulling our 6,000 pound trailer, and I couldn't get excited about 6.0L/6spd. I haven't checked mileage on just towing yet, but am very happy with the way the truck went down the freeway with the travel trailer in tow.
   / New GMC 2500HD 6.0 GAS Opinions #5
It is actually a different engine than the older ones have. The new ones have Variable Valve Timing (VVT). Also, the new 6 speed tranny is not an allison but it is a GM 6L90. Lower 1st gear, 2 overdrives with the second being higher than the old ones overdrive. You can go here for more information: GM Media Online: English (make sure you pick the correct engine. In the tranny column you will see the 6sp tranny).
I have not heard any actual fuel economy numbers but I have heard positive feedback when compared to the old body style.
Kurt
   / New GMC 2500HD 6.0 GAS Opinions #6
I have an 07 chevy 2500 crew cab 6.0 with auto trans 4:10 rear end, utility bed, ladder rack 8' bed I can pull a trailer 80 down the hwy if I want but the mileage is about 11 mpg without a trailer, don't know what it is with a trailer.
I do have a pretty heavy load with all my tools and stuff in the utility bed.
   / New GMC 2500HD 6.0 GAS Opinions #7
I have a 06 2500HD 6.0 with a five speed and 4:10 gears that we use to run between fields with..been a great truck and pulls great (pulls 26 ft trailer, ford 3930 with front loader and large hay rake)
   / New GMC 2500HD 6.0 GAS Opinions #8
You might want to look into an 05 or 06 with a diesel in it. I don't think the diesels are selling right now. I got 20.6 mpg hwy last week with my 05 Duramax but was going slow, 58mph. At 65 mph I would get 18-19 mpg. If you pull alot a diesel is nice. If you go with the 06 you get the 6 speed too with only a little more emissions.
   / New GMC 2500HD 6.0 GAS Opinions #9
I would suggest that, too. Look for a 1-2 yr old diesel. That way you get the allison, and it will have a ton of warranty left on it.
Either that, or wait a little longer. GM will probably be installing the 6.2L V-8 with over 400HP for the '09 model year. It's already in the Tahoe.
   / New GMC 2500HD 6.0 GAS Opinions #10
Actually, the additional emissions (DPF) didn't start until 07.5. I have the 06 LBZ Duramax with the 6-speed Alli and do not have the DPF. The 07 Classics don't have it either. Didn't start until the new body style 07.5 trucks.
Oh, and I love the duramax. Came from a 4.8 1500 truck and a 5.3 Suburban. I could tow them both at the same time, plus my tractor, and maybe the house too. heh. :p
2019 Ford Fusion Sedan (A51694)
2019 Ford Fusion...
2016 Utility 102"x48' Flatbed Trailer (A50123)
2016 Utility...
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2019 Hustler X-One 60in Zero Turn Mower (A51691)
2019 Hustler X-One...
