new gilson owner
/ new gilson owner #1
gilson71
bridgeport, texas
ward/gilson garden tractor
I've recently purchased an older ward/gilson garden tractor, and I cant get any spark out of it, needto know kind of where to start.
/ new gilson owner #5
Some pictures would help, but usually rusty flywheel magnets are the culprit if it has set outside, or just set for a while. Remove the shroud covering the flywheel, and look for the magnets. Should be two, cast into the, I'm assuming aluminum flywheel, so they'll be easy to spot. Polish them with some fine, like 400 grit sandpaper. Or, I use my air angle die grinder with a Roloc pad for removing gaskets. Buffs them right up, with little work. I normally clean further to remove the dust with some brake cleaner, or a bit of WD-40 on a shop rag. I like to polish up under the coil pick-ups too with a single layer sheet of fine sandpaper, or crocus cloth.
If still no spark, could be the condenser, or points. Depending on the brand and model of the engine as to their location, you may need to remove the flywheel to get to them.
Again, a few pics from different angles would be a big help.
Informational Lot - Financing (A63689)
Informational Lot...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
