New garage time!
   / New garage time!
Not everything is perfectly true, square, and plumb. That's why I wanted to use the panels instead of templates.
I also am spacing the panels with 16p nails to allow for some expansion. They're mounted on rubber washers to insulate the materials from each other.
I want them as close as possible to each other. Then I'll cover the gaps with butyl aluminum tape to make the roof waterproof.
I have another set of rails that I need to mount, that'll account for 12 panels, then i'll need to go get more rails for the 3rd and 4th set. Then after that, I'll need to get more framing to build more structure.
But 24 panels will be enough to get me started with my 4x3kw growatt inverters.
   / New garage time!
Back almost better, another panel up. 3 more inverters arrived today. Finally have to finish the laundry room I guess.
   / New garage time!
I have a tree in the way of my solar at about 4pm. Can I top the tree to make day longer?
   / New garage time!
I've never missed a tree that I removed. Take it down and never have to deal with it again.
It’s to big of a job right now. It comes up in the middle of my chicken run and provides great shade for them.
   / New garage time!
Got the first row finished and the racking up for the second row. Hopefully will be done tomorrow.
I broke my $18 bit on the 23rd hole I drilled, it snapped in half. It claimed that it would stay sharp 15x longer, but it didn't say it wouldn't snap in half. It's probably still sharp.
   / New garage time!
Got the second set of rails up and the first panel on that set. It's a lot easier now because I can measure off the first. Which means I can drill on the ground and not on a ladder, which makes a big difference.
I'm out of angle iron, which means I need to go to the steel shop for more. I'm trying to think what else I need while I'm there. Eventually I'm going to put roof on the other side, I'm not sure if that's what I'm going to do right away.
So there's 15 panels per inverter, I have 4 inverters, so the obvious solution is 60 panels. Challenge is I can only fit 48 even if i extend to the full back of the house. I'll probably round that to 45 to make life simpler.
So I need to find a place for 15 more panels.
Also, I'm working alone so yes this is obviously going slow. Everything is heavy, and I'm making everything myself from raw materials. But I try to make progress every day.
   / New garage time! #1,359
Are you going to do anything to make the underside of them more attractive?
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2011 International DuraStar S/A Refer Truck (A55272)
2011 International...
2017 Ford F-550 (A55973)
2017 Ford F-550...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
