New garage time!
   / New garage time! #1,211
The real bummer is tomorrow is the last day above freezing, so i have to finish laying the block. Then comes the big freeze. I cleaned my finger up mostly and bandaged it, but it's not the only one that got chewed up.
Ouch, that limestone is no good for your blood. Hope you don't play guitar for a living.
   / New garage time!
I like laying block too, but my tennis elbow starts kicking in from gripping the block. Same as spitting firewood, I have to break it up with days between. And I never played tennis.
My issue is my hands, bad arthritis in my thumbs. If I push to hard, like last time, I couldn't hold more than a coffee cup for a week without intense pain.
   / New garage time!
Oil guy came to fill up the house. I asked him to also fill my 2 55g drums as well. I got my fueling station out of the old garage and into the shop last night, easy with the barrels empty. He was nice enough to fill them for me. Then I got my pump and power hooked up, and the barrels into place. Added my diesel additive as well. I should be good for a while.
   / New garage time!
My weber rollers were to high for my bandsaw. So I made some adjustments to them. I was concerned about some questionable reviews on the saw, some said it's precision leaves something to be desired. I haven't found that on mine so far.
   / New garage time!
I was putting some stuff on the second floor of the garage, and as I was riding the elevator up, something caught my eye. One of the joists didn't look right.
At first I thought my eyes were playing tricks on me. The joist looked bent. And a few joists beyond it. And while it's hard to tell it looks like it goes all the way down the line.
Everything is still very secure, i looked for other joist not looking uniform, but didn't see any spots other than down that line. That side of the building is unprotected from any wind break. So I'm wondering if the side wall is catching wind in such a way that it's somehow causing a bend in the joists down that line, since that would be the weakest point closest to the wall.
Forgive the POS level, i just wanted to grab a strait edge to see if I was seeing things. It looks like the bow is on the top as well as the bottom.
   / New garage time! #1,216
What are those joist made out of? I thought they where metal, but the way they are bending, it doesn't look like metal.
I think you need to call the manufacturer that made them, and talk to an engineer there. Something like this will only get worse over time.
   / New garage time! #1,218
With the bends occurring above and below the port/cutout, I would think that is the culprit? Maybe you could weld some plates over the holes?
   / New garage time!
That's an idea. I have to figure out what's actually bending. It doesn't look like it's dropping, more like compressed since it's bowing at top and bottom. I checked the other ports down the line and it's not happening there. It's only happening on the second porthole.
I have no idea when it happened, if it was a one time thing during a heavy storm. I think i may plant some tree's or something as a wind break because that side wall just does nothing but catch wind when it storms.
   / New garage time! #1,220
Unless there are signs something is about to break I probably wouldn’t worry about it. Steel bends and forms a little like wood.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Bobcat T595 (A55272)
2017 Bobcat T595...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2024 DOWN TO EARTH 8' X 26' HYD TILT TRAILER (A52708)
2024 DOWN TO EARTH...
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
