New Fencing
   / New Fencing #11
Tighten your fence at the wood posts, but like Chris said, you pull it tight using your tractor or by attaching a come-along to your tractor. Try to avoid using your wood posts as the anchor for the come-along. Once you have your tension, staple the fencing to the wooden posts, I use 2" galvanized, then tie up the fence at each T-post before releasing your tension. The T-posts simply hold up your fencing. They will not maintain horizontal tension.
The clips Bird is talking about usually come with your T-posts. TSC will typically provide 5 clips per. Since you said you have existing T-posts, Bird showed you where to get the clips.
   / New Fencing
Thanks for the help. I am talking with my local butcher to supply some sheep and goats for them. I just needed to make sure the fence was up to the task before starting this.
Steve
   / New Fencing
The few goat we currently have are pets. They get out to come visit when we are outside. I have found them in the house a couple times when the boys left the door open. We just reseaded some of our pastures due the the damage caused by the drought last year. Boy seed is expensive these days.
Thanks for all the help.
steve
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
(INOP) JOHN DEERE 317G SKID STEER (A52705)
(INOP) JOHN DEERE...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A54865)
2012 Ford Transit...
Kubota ZD21 Zero Turn Mower (Diesel) (A54865)
Kubota ZD21 Zero...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
