New farm... Finding livestock water lines across 126ac?
   / New farm... Finding livestock water lines across 126ac? #71
I'm not good at using dowsing rods, but thankfully I don't have to be.
The affordable Pipe Finder detects just about everything (which is good and bad), including empty PVC pipe.
   / New farm... Finding livestock water lines across 126ac? #72
I have a locater that can find electrical pipes, or any pipe i can force a fish tape into. But it wont work on an active community water system.
   / New farm... Finding livestock water lines across 126ac? #73
What is this portable pipefinder your talking anout?
   / New farm... Finding livestock water lines across 126ac? #74
Checked Amazon, found the Magnetomatic Pipe Locator.
It's more expensive than the Pipe Finder I have, but seems to be very similar. Basically a telescopic antenna on a very low friction handle.
   / New farm... Finding livestock water lines across 126ac? #75
Thanks, that looks similar to the dousing rods i made from copper wire.
   / New farm... Finding livestock water lines across 126ac? #76
All this talk of dowsing and witching; we have several fixed features; a meter box; and 5 waterers, each that we know (or we think we know) are part of one system. So, we have 6 known points. We can witch if we want, but that doesn't change the fact, we have to spot dig the line. It's not that bad to dig around the line at one waterer, see the direction it's heading, go down 50 ft, and dig a slit trench to confirm, and go down another 50 feet. If we do a 5 ft wide slit trench, perpendicular to the running line, vs a 10 ft slit trench, cause we have a better idea with the witchy sticks, great. We still need to get a shovel out, and start digging.
Once we have a layout, you can find valves, and start turning them on, 1 at a time, and decide if repairs are needed/worth it; and then more shovel time.
It would be nice if there was a less manual way, but there really isn't. Just start at one, and get after it.
   / New farm... Finding livestock water lines across 126ac? #77
In many area with rocks and frost to worry about that would be a lot of digging.
   / New farm... Finding livestock water lines across 126ac? #78
Based on his stated location, 24-27" frost line max. Now, rocky conditions do make it somewhat worse, but I would assume the original installer didn't backfill with rocks? If the soil is rocky in most of the area, it might be pretty easy to spot the trench line as you come across it.
   / New farm... Finding livestock water lines across 126ac? #79
Around here it seems the generally accepted way is to keep the big rocks out the first foot of backfill after that just shove in what you dug out.
   / New farm... Finding livestock water lines across 126ac? #80
I think you will find the same thing here.
I do take the time to pick them out, because I'll be the one digging up anything I bury.
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
John Deere 1025R (A53317)
John Deere 1025R...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
