New Everlast 160
   / New Everlast 160 #1
dkf1998
Maine
New Holland TC40DA, John Deere Model L
I just purchased a PowerARC 160. I have to thank Mark for a great deal, he was very helpful and great to deal with. This is the first time welding with an inverter and was very impressed to say the least. I tried some 7014 per Mark's recommendation and WOW!!! I could not believe how easy it was to run, I also tried some 6011. I didn't have any 7018, but will try some asap. The 160 has a very smooth arc and is well built, I am very impressed so far.
   / New Everlast 160
What's the first project?
I am going to do a lot of TIG practice; t-joints, butt joints and such. I am fresh out of a TIG class and want to reinforce what I have learned. As far as ARC goes, I am thinking about building a squat rack.
   / New Everlast 160 #5
When building my squat rack I used pallet racking frames for posts to utilize the vertical adjustments without having to drill 160 1" holes in square tubing. Just a thought.
Terry
   / New Everlast 160
Terry
That sounds like a good idea, but I don't know where I would find pallet frames. Do you have any pics of your squat rack?
   / New Everlast 160 #7
That sounds like a good idea, but I don't know where I would find pallet frames. Do you have any pics of your squat rack?[/QUOTE
You should be able to find pallet racking easily from a local material handling or industrial shelving supplier. Although I had access to used material my dealer special ordered the posts individually for me from the factory. Two vertical posts are usually welded together with cross bracing to create the end frame for the pallet racks.
I figured it would be more cost efficient doing it that way than cutting and grinding. Plus I had the benefit of new factory paint, which although not powdercoated is relatively durable. I also purchased the frame brackets individually and welded them onto the ends of 2"sq tubing for the spotter bars. (And for the adjustable barbell "hooks")
Terry
   / New Everlast 160
Terry
Those look nice, thanks for posting them. I am actually going to build a set of Squat stands similar to these. I need something more portable than the ones have now.
   / New Everlast 160 #9
dfk1998 that should make for a great first project for your new welder! Have fun.
Terry
   / New Everlast 160 #10
Terry
uhm.. wow on the weight room.. I can't be the only one thinking it.
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
Deere 325G (A50123)
Deere 325G (A50123)
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2019 Komatsu D51PXi-24 Crawler Tractor Dozer (A51691)
2019 Komatsu...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
