New DK40
   / New DK40 #11
</font><font color="blue" class="small">( Thx for your feedback John.
I should have added that it makes the sound when i don't touch the steering wheel; when i turn the wheel a little the the left or right the sound stops. Could that be as you suggest air in the system?
Wekke )</font>
Well I'm going to hazard a guess that what you hear is whatever system these tractors use to protect the hydraulic pumps from cavitation in a low flow situation. In this case the power steering pump. If it’s a spring loaded diversion valve your tractor may not make enough pressure or flow to lift it cold and/or the flow is sufficiently reduced to keep the line quiet. Once you’re warmed up you get the noise and then when you move the wheel the flow is diverted to your steering rack so it goes quiet. Just my guess. /forums/images/graemlins/wink.gif
Regards, Jamie
   / New DK40 #12
Wekke )</font>
Regards, Jamie
   / New DK40
Thx Jamie,
I'll check this with my dealer ...
Should i hurry and contact him as fast as possible, or doesnt the lack of pressure present danger to cause more damage in the short term?
Regards
Wekke
   / New DK40
Thx Jamie,
Regards
Wekke
2005 DODGE RAM 1500 (A58214)
2005 DODGE RAM...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
5' SCRAPE BLADE, 3PT (A52708)
5' SCRAPE BLADE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
