new cushion valve on log grapple
/ new cushion valve on log grapple #1
quietrangr
Frederic WI
1992 230 Timberjack forwarder with Serco loader
Hello,
I have an older Serco 4000 with bypass bucket. When I turn the bucket, the momentum keeps it going maybe 10 to 20 degrees after I let off the lever. The bucket will also turn by itself a small amount--just coasting, doesn't seem to be under any power. Do I need a new cushion valve, and if I do, what kind of relief pressure should it have?
/ new cushion valve on log grapple #2
Sounds like a sticking valve(slow acting);cushion valve won't help ,I don't think.May slow it down but not stop it.
A flow control "may" help.
/ new cushion valve on log grapple #3
Get a pressure gauge and test the valve. I have a cushion valve on the swing for my BH I built, when I first used it the reliefs were set too low and has too much movement after I let off the control under normal use.
I can't remeber the exact pressure I set mine over the main relief but you would be safe as long as they are set at the working pressure for the components. You could most likely go over a bit as as long as its below the max pressure for the components.
Thanks, guys. Sounds like a pressure gauge is the way to go, maybe testing both the control valve and the cushion valve. Thanks.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
65' Extension Cord Reel (A66408)
65' Extension Cord...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
More info coming soon (A61569)
More info coming...
