New Cub Cadet owner!
   / New Cub Cadet owner! #11
Sounds like it could be just the heat shields cooling off and popping.
   / New Cub Cadet owner! #12
   / New Cub Cadet owner! #13
When you shut it off; use a piece of metal conduit or copper and use it like a stethoscope to isolate the noise. My guess would be the muffler. You could pull the spark plugs and check there condition; should be gray for normal; if white; it is running lean; which means hotter than normal. Black means it is running rich. Also make sure the correct spark plugs are installed. If it is lean; just richen up the high speed carb adjustment. Also a pressure washer can clean up the tractor very well.
   / New Cub Cadet owner! #14
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2015 BMW 328i Sedan (A55853)
2015 BMW 328i...
403 (A52706)
403 (A52706)
Mobile toilet with shower (A53424)
Mobile toilet with...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
