New Cub 2544: first impressions!
   / New Cub 2544: first impressions! #1
JTKub
West Falls, NY
TYM T224
New poster here! Been lurking for a bit, just got my new 2544 yesterday. Wow this thing is BIG compared to my MTD 600 series.
Seating is WAY up high. Kind of van-like. Seat is large, comfortable, supportive (like me:eek:))
Fit & finish look good at this point. Nice paint. Nice plating on all hardware, plastic parts not too bad. Everything tight.
Nice model specific ops and parts manuals.
The kohler command 20hp lit off with a bump of the key. This is my first V-twin piece of OPE. I love the low-tone, mellow exhaust note. Has a nice ‘harly-ish’ ratta-tatta-tattta. Really cool sound when you throttle it up. Not a hint of black smoke, no nasty exhaust smell. I killed the ignition several times at idle. No backfiring like my 17hp briggs single if you forgot to s/d at hi throttle (thank God!).
It’s HEAVY. I used to be able to lift the back end of our 1992 JD GT262. I can’t budge the CC 2544.
I’m not sure if the 2005 44" triple blade deck is an all new design, but it’s super deep & the hardware seems well laid out & easy to maintain. It barely sticks out from the sides of the tractor & the deflector is nice & short. Glad to hear it does not roar like a 747 when engaged!
The pedal drive hydro is nice. Will take me some getting used to since it’s the first non-gear dive I’ve ever owned. Hydro sure seems like a smart way to go for any LT/GT.
Now for the not so great(s):
Setup was poor. Not sure they did anything but gas it up & make sure everything works. One tenth of an hour on it. Tire pressures were all over the place, HUGE globs of grease on every zerk & this red sticky spray lube sprayed all over every linkage, hinge, battery terminals etc. Overspray was free of charge apparently. Machine was fairly dirty as well.
Some of the wire routing & protection is questionable. For ex. Headlamp wiring close to exhaust heat shields, Several single ‘fuse holders’ just float around near the battery. I’ll have to touch those up with cable ties, wire wrap/loom.
Mounting/dismounting is awkward with the deck raise lever on one side & the deck discharge on the other.
Pretty much every stick-on decal, including the rear taillight reflectors needed to be reseated. The decals themselves are a heavy mylar material, but the adhesive is questionable. Again, this is a setup issue. Their delivery guy (kid) blasted it up the driveway @ full speed, turned it over to me & bailed. He still had several 1000 series on the trailer (at 4pm) Said he’d been going non-stop all day. I really can’t be too tough on the dealer. 1) this is their BUSY season. 2) Their sales/service/parts/availability are awesome.
So far so good. Time will tell. It’s no JD GT/GX, but it is the best you are gonna get for $2999.
Sorry for the long post!
THANKS!
Joel
   / New Cub 2544: first impressions! #2
Joel;
Good to here! It's a very impressive tractor. I ordered mine 3 weeks ago from local Lowes and the attachments haven't come in yet, but I did get to check it out, and sit on it, and its up high. Started easily and like you say mello exhaust note.
I can't wait to see it with the tiller on and what the sleeve hitch attachment set-up is like, if its beefy enough I'll use it for hauling/box scraper? with a reciever hitch on it.
That cast iron rear axle added a good amount of aft weight.
Should make using it easy when attachments are on.
Let's see some pic's
Todd
   / New Cub 2544: first impressions! #3
<font color="purple"> 1*the deck barely sticks out from the sides of the tractor
2*the deflector is nice & short.
3*Setup was poor
JTKub
1*This makes it more difficult to mow around trees up close to obstacles and to trim along ditches.
2*and easier to slip a foot under.
3*Did you check oil and fluid levels? </font>
</font><font color="blue" class="small">( <font color="purple">1*This makes it more difficult to mow around trees up close to obstacles and to trim along ditches.
3*Did you check oil and fluid levels? </font> )</font>
1) No. Not really. Tried it. For my application, it's perfect.
2) Can't reach my feet down that low while mowing /forums/images/graemlins/wink.gif. If a bystander walks into the side of the tractor (unbeknownst to me) while I'm mowing, it doesnt matter what size the deck is /forums/images/graemlins/tongue.gif.
3) You bet. Have been all over it. Top to bottom, left to right.
Thanks
Joel
2010 Nissan Sentra Passenger Car (A51694)
2010 Nissan Sentra...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
2014 Chevrolet Cruze LTZ Sedan (A50324)
2014 Chevrolet...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
