M59
Platinum Member
- Joined
- Oct 27, 2014
- Messages
- 557
- Location
- Fairview NC
- Tractor
- Kubota M59 TLB/ Mahindra Max 24 TLB/ KX-080-5
90cummins,Thanks for that info M59.
The floor was replaced because the original was cracked & not level side to side. There was a 5 inch elevation difference across the width of the doors. We ordered a new 17’ door which required the floor to be level. This is only used for parking in the winter so I’m primarily interested in products that will prevent salt damage.
Industrial coatings are out of my price range so I’m looking at pour on/spray-on treatments to seal the new concrete before winter.
Thank you
90cummins
Got it, cost is critical, then regardless of what coating you choose, prep that floor so you can bind what ever coating you choose otherwise the coating will soon peel off. Mechanical prep is best, acid prep isn't aggressive enough. Floor prep is far more important than coating choice to a long satisfactory life for coated floor.
