New concrete floor coating advice needed.
   / New concrete floor coating advice needed. #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I just removed the old concrete floor and apron in the house garage and I’m putting in a new floor approx 6” thick. I would like to coat/treat the new concrete to protect it from road salts & freezing & thawing.
What would you suggest?
I’ve looked on line at many products but would like some real world experience suggestions.
90cummins
   / New concrete floor coating advice needed. #2
I would use the really high dollar epoxy paint like they use in aircraft hangers. Prep is important and it’s expensive.
   / New concrete floor coating advice needed. #3
Proper troweling and curing is the first step because without it no coating stands up well.
   / New concrete floor coating advice needed. #4
90cummins
I would use an air entrained (5 to 6 % air entrainment) 3500 lb or 4000 lb mix, solves the road salt issue and the freeze/thaw issue.
Your local concrete batch plant will know how to mix it with the local materials available.
   / New concrete floor coating advice needed. #5
The surface densifiers are supposed to be good at making a pretty impervious surface but I have not used them myself.
Could you recommend any particular product?
90cummins
   / New concrete floor coating advice needed. #7
90Cummins,
Surface prep, Surface prep, Surface prep. I can't say it enough. I have built several facilities where we used metal plating chemicals and before the 2 part epoxy floor was placed, with 3/16 inch cured build, the floor was shot peened to scour the surface of any contaminant BEFORE the epoxy was laid down. Shot peening or surface grinding removes the smooth surface and provides the epoxy places to grip the roughened surface. To get a 3/16" build, we mixed in fine CLEAN silica ( sand ) and trowled on with a rubber floor squeegee. The squeegee floats on top of the silica when spreading the filled epoxy. The silica also provides a grippy surface since straight epoxy is very smooth/ slippery when wet.
To get a 3/16" build, we laid in two layers with second layer added when the 1st layer was tacky ( partially cured ) to get good bond/ cross linking between layers. You will need a set of "nail shoes" to walk on the semi cured epoxy. Nail shoes strap to your shoes and have short pins ( 1/2" long ) on the bottoms so you can walk on the epoxy.
I don't have a specific brand of two part epoxy since different brands are predominant in different areas of USA. Look at specs for chemical and physical damage ( dropped tools, hammers ) resistance.
Have fun. You can build patterns using colorant so your artsy side can be part of the project if you are so inclined. I personally have used fine chipped colored black glass in a white epoxy and red/ white/ blue since I enjoy the BMW marque.
Thanks for that info M59.
The floor was replaced because the original was cracked & not level side to side. There was a 5 inch elevation difference across the width of the doors. We ordered a new 17’ door which required the floor to be level. This is only used for parking in the winter so I’m primarily interested in products that will prevent salt damage.
Industrial coatings are out of my price range so I’m looking at pour on/spray-on treatments to seal the new concrete before winter.
Thank you
90cummins
   / New concrete floor coating advice needed. #9
Thank you
90cummins
Holly molly that's some bad settling, is the building sitting in a swamp?
   / New concrete floor coating advice needed. #10
For a densifier, someone once recommended Ashford Formula to me, but I have no personal experience with it.
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2011 International School Bus (A49461)
2011 International...
hand held concrete saw (A49461)
hand held concrete...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
