New Computer Has Me Screwed Up!
/ New Computer Has Me Screwed Up!
Muhammad,
Would using that remote connection feature that was mentioned earlier be something that we should consider doing? Would (could) we hook up to you? As I understand it, then you could work directly with my system, right?
/ New Computer Has Me Screwed Up! #102
Since it's a display setting/configuration issue with your machine, I can't offer much more support than what has already been posted. If it were my computer, I'd reinstall IE, and if that failed, try Firefox and see how that looks.
O.K. I'll see what happens when I try the re-install.
I REALLY appreciate all of you guys taking the time to respond to this problem.
Alrighty Then!!
It looks like Hakim's suggestion worked!! I downloaded Internet Explorer 6 SPI, and I have a full screen back. I've attached a screen shot.
I still don't understand why I don't see any of the horizontal bars I used to see. Those are the ones that the name of each forum was in. It helped separate the different forums. And I also can't get any of the colors preferences to work (JD, Kubota, NH, etc.), or the font color chart. Any ideas on what's wrong with those? /forums/images/graemlins/confused.gif
But I suppose I can live with this. I'll probably keep messing around with settings to see if I can get back to what I used to have, but it probably won't do any good.
Anyway, thanks to all who offered help. But especially to Hakim! You Da Man!! /forums/images/graemlins/grin.gif
/ New Computer Has Me Screwed Up! #105
Garry,
Did you look in "my Home" here on TBN.........you can change the themes. When I changed mine to white , my screen looked just like yours.
Yeah Jerry, I did. It doesn't matter which theme I select, the screen always looks the same. The only thing that will change is the font size if I select one of the smaller font size selections. I usually change once every couple of months just for a little variety. I happened to have it set for JD when all of this happened. Now I can't get any color on it, other than what you see in the screen shot that I posted. And ikt's not even the loss of color that bothers me the most. I'd really like to get back those forum banners or headers or whatever their called that separates each forum section from the next one. Without them, everything kind of runs together. /forums/images/graemlins/frown.gif
But like I said, I'm just happy to get the full screen back, so if I don't get these other "nice to haves" back, well that's O.K. /forums/images/graemlins/crazy.gif (kinda, sorta!)
/ New Computer Has Me Screwed Up! #107
Gerry,
Try adjusting the brightness and contrast settings on the MONITOR itself. If these get out of whack, it can appear to drop out the "lines" and other separators. Nudge the settings and see if you can re-create a contrast balance that "shows" the lines. The contrast and brightness settings are usually on the bottom panel of the monitor. Sometimes they are behind a hinged "door."
Hmmmmm..... /forums/images/graemlins/confused.gif
Tried adjusting as you suggested, and I could not see ANY changes of any kind.
/ New Computer Has Me Screwed Up! #109
Now I know why I chose Netscape over IE. No problems like that have happened to me yet.
/ New Computer Has Me Screwed Up! #110
<font color="blue"> Any ideas on what's wrong with those? </font>
Unlike a CRT, LCD monitors usually have one recommended display resolution, at least the 2 LCD monitors I have, as well as my laptop, do. For example, my laptop can only run at 800 x 600 while the LCD on my daughter's PC will display a warning message if I try and use a different resolution. Sometimes they will work at other resolutions, but the picture quality suffers.
Might want to check the display owner's manual to see what the recommended resolution is.
Mike,
I've been playing around with the settings on the monitor. I don't need no stinking manual!! I'm a guy. Come on! /forums/images/graemlins/wink.gif /forums/images/graemlins/crazy.gif
Seriously, I did try resetting the monitor settings to the defaults, but it made no diference. I still think if I just continue to "tweak" things a little, I'll get it.
Thanks for the suggestion. /forums/images/graemlins/smile.gif
/ New Computer Has Me Screwed Up! #112
Did you try Firefox, yet? It is based on the Mozilla platform as is Netscape. I am using Netscape and I like it a LOT better than IE. One thing that drove me nuts about IE is, if I went to a secure site it would literally take IE forever to connect to the site. When it did I could see the little lock symbol change to the locked position. Whenever I had to go to a secure site, I just cringed. Netscape handles secure sites much quicker and better. /forums/images/graemlins/smile.gif
This thread has sure gotten long! I don't remember, and if you already mentioned it sorry, but do you get display problems when not using IE?
Jay,
Apparently my display problems were due to corrupted file(s) in IE. Once I downloaded IE 6 SPI, the screen problems were eliminated. And I think that the color problems and not seeing the Forum headers are just a matter of tweaking the settings.
My biggest problem with trying something like Firefox, which I would be more than happy to try out, is that the computer is actually my wife's business computer. She and 2 other ladies use it more than I do, so you might say there is some resistance to any kind of change. /forums/images/graemlins/crazy.gif So unless something drastically wrong happens that is directly connected to IE , there is no way trying something else will fly. No matter how much better it might make things. /forums/images/graemlins/frown.gif
So for now, the major problem has been resolved. I'll keep playing around until I get the display just where I want it, or until I get my own computer! /forums/images/graemlins/smirk.gif
/ New Computer Has Me Screwed Up! #114
Garry,
Thankfully, Firefox is no where near as intrusive as your typical Microsoft product. The entire application is installed into a sigle directory for the executables, and another single directory for data. I believe that the only registry modification would be if you say "yes" when Firefox asks you if you would like to use it as the default browser.
In my most humble opinion, you can safely install Firefox for trial purposes, with no risk to the functionality of the computer.
Dave
/ New Computer Has Me Screwed Up! #115
</font><font color="blue" class="small">( So unless something drastically wrong happens that is directly connected to IE, )</font>
About a couple months ago (you may remember my thread), I got a real bad hijacker/virus. Aren't they lovely? /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/mad.gif I am convinced that because I was using IE that my computer became so infected. IE is the most targeted browser for things such as malware and hijackers. Those things are coded for it. Because IE is so "deeply" installed in the system, the lovely hijacker/virus I picked up also infected Media Player. Wmplayer.exe would download and install that nasty little bugger! /forums/images/graemlins/shocked.gif If I were using something like Netscape or Firefox at the time, I believe I wouldn't have had to go through the hassle of reinstalling Windows and everything I needed.
/ New Computer Has Me Screwed Up! #116
Garry,
Like the others said, FireFox (or another browser) is probably going to solve all of your problems and maybe even some you don't know you have! /forums/images/graemlins/tongue.gif
The security problems with IE (and Outlook, and Windows, and ...) has just gotten to a point were you can't trust it anymore. Even the US homeland security agency recommends that people don't use IE!/forums/images/graemlins/mad.gif
For my part, I'm pretty much trying to stay away as much as possible from any MS products... It's not easy but certainly possible and cheaper too!/forums/images/graemlins/cool.gif
Hypernix
/ New Computer Has Me Screwed Up! #117
After I thought I had removed the hijacker/virus I decided to reinstall IE. I opened Control Panel - Add/Remove Programs. I then double clicked the IE selection. I chose the repair option. During the process the dumb thing popped up an error message. After that point, I tried reopening Control Panel. When the window opened nothing showed up inside! I then clicked My Computer. Nothing! Something had erased ALL my icons within those windows when I was trying to repair IE. Also, for some strange reason I couldn't search for Files or Folders, either. At that point I decided to reinstall Windows.
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2014 VOLVO VNL (A60736)
2014 VOLVO VNL...
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2000 Sterling L9513 Winch Truck (A61307)
2000 Sterling...
