New clutch will not disengage
   / New clutch will not disengage #1
Norwegian Viking
Iseki TX1300F
So i have tried to change the clutch on my iseki tx 1300.
And when i put everything back together the clutch will not completly disengage. I can turn the wheels barely with the clutch pedal pressed down and in a high gear.
Tok everything apart and noticed that the pins on the clutch had been grinding on the pressure plate.
What is going on here?
New clutch i bought is from here: Clutch Kit Iseki TX series | TX1210 - TX2160F | Bolens G152 - G154 | G172 - G174 | Shop4Trac
And the clutch plate will only fit 1 way, so its not installed backwards.
   / New clutch will not disengage #2
Compare the new parts to the old parts to see if there is something different in the manufacture.
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
44" HYD MINI WOOD GRABBER BUCKET (A60430)
44" HYD MINI WOOD...
Kubota M5-111 (A53317)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
