New clutch time
   / New clutch time #1
repete
Veteran Member
SW Washington
L2550DT IH584-4WD
After 5,500 or so hours the clutch on the L2550DT finally bit the dust. About three hundred dollars to replace both discs, throwout bearing and engine main seal due to a small leak. Never had this little guy in half before. Hopefully just discs and not pressure plate.
   / New clutch time #2
While in there, Replace the pilot bearing in the engine flywheel... If it did not slip a lot and overheat the pressure plate will likely still be good...
   / New clutch time
I forgot to list the pilot bearing as well.. I just noticed it slipping so hopefully I caught it in time. I thought I felt something not right after adjusting the clutch freeplay so I put it on the hill on the driveway and let the clutch out in 3rd high and the engine revved and tractor only moved slowly forward. Enough tests, in the shop it comes.
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A51248)
UNUSED WOLVERINE...
UNUSED FUTURE FR70 69" LEVELER (A51248)
UNUSED FUTURE FR70...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
International Cab and Chassis (A51692)
International Cab...
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
